Latest post 08-27-2009 8:26 AM by Razlaw. 31 replies.
Page 1 of 2 (32 items) 1 2 Next >
  • 12-24-2008 8:15 AM
    • Bieele
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Netherlands
    • Posts 339
    New Beosystem 3
    Who knows more about a 'new' beosystem 3?
    What is new about it? New soundprocessor? Will the old one be upgradable?
    Very curious since I am in the market to buy one.
    Bieele
    Heej zuij der alles veur gaeve En heej zaet ze mogen ut hebbe van meej
  • 01-02-2009 6:40 PM In reply to
    Re: New Beosystem 3
    Hi Bieele
    Actually I don’t know the difference ether, but I can see that the type # ( in the new pricelist Jan 2009 ) has changed from 9600 to 9615. If anybody what we can expect from the “new“ BS3, I’m very interested to. Could also be nice to know when this new BS3 are implemented in BV9…
    Kim
  • 01-02-2009 8:24 PM In reply to
    Re: New Beosystem 3
    Very curious, indeed. Haven't heard of an MkII as some have mentioned. Have heard of the inclusion of DSP but everything else discussed, hardware or software related, would be able to be fitted or swapped into the existing chassis.
    Of course, several type numbers have developed simply because of the changing of interior components. This doesn't necessarily mean an upgrade, downgrade, or sidegrade.
    There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
  • 01-03-2009 9:55 AM In reply to
    • Bieele
    • Netherlands
    • Posts 339
    Re: New Beosystem 3
    Maybe HDMI 1.3?
  • 01-10-2009 1:53 PM In reply to
    Re: New Beosystem 3
    In the German forum in a thread discussing the european dealer conference it was mentioned that the BS3 would get an enhanced soundsystem in spring.
    Older BS3 could receive a hardware update,
    http://forum.beoworld.org/forums/thread/139933.aspx
    So this might be it.
    Cheers
    JK
  • 01-10-2009 2:32 PM In reply to
    • BeoNut1
    • Top 500 Contributor
    • Joined on 08-19-2007
    • Mobile, AL (USA)
    • Posts 226
    Re: New Beosystem 3
    It would be great if the "enhanced" sound system not only included HDMI 1.3 and DSP, but also a coaxial digital output so that those of us trying to use the BS3 as an audio head in an A/V system could directly connect BL5s in the most advantageous manner.
    M
    Mark D
  • 01-10-2009 7:12 PM In reply to
    Re: New Beosystem 3
    New BeoSystem 3 ... are you sure? I don't think so. Far too early for that in my opinion. What 'really' could be improved?
    Simon.
  • 01-10-2009 9:13 PM In reply to
    Re: New Beosystem 3
    I wouldn't say new, it does have though a different part number in the new price list and an "updated" sound system was announced in the german thread I am refering too.
    Cheers
    JK
  • 01-11-2009 11:27 AM In reply to
    • Alex
    • New York, NY
    • Posts 176
    Re: New Beosystem 3
    Theres no difference except for a RAM upgrade.  As far as I can tell the MKI units will be upgradeable.
    Store Manager Bang & Olufsen Broadway 927 Broadway New York, NY 10010
  • 01-11-2009 12:31 PM In reply to
    Re: New Beosystem 3
    Apparently the BS3 has been upgraded with some hardware to accommodate 'an exciting new technology' but at present there is no change in operation. Make of that what you will!!
  • 01-11-2009 12:48 PM In reply to
    Re: New Beosystem 3
    That sounds good!Smile
  • 01-11-2009 2:05 PM In reply to
    Re: New Beosystem 3
    What I think is new: " Rumour go’s Beosystem 3 new feature will be the possibility to set up the place the viewer actually is in the room. So to speak “where we Beoworlders are enjoying our movies in our own cinema!”.
    To adjust the (Dolby) speaker setup. Not sure if it is software only….(who knows?)
    (A bit like in the premium Audi’s with advanced B&O sound system. One can setup All, Driver, Front, Rear etc. (DSP Bang & Olufsen setup)
    Regards, Robert
  • 01-11-2009 2:08 PM In reply to
    Re: New Beosystem 3
    The_Beonic_Man:
    Simon.
    Add USB and add a SD card reader possibly. Who wants to improve more on the BeoSsystem 3?
    Regards, Robert
  • 01-11-2009 2:52 PM In reply to
    Re: New Beosystem 3
    -multimedia Robert-:
    Regards, Robert
    That feature would be software only. Another rumoured feature is the possibility to plug a microphone, place it in the middle of the room and get the system to calibrate itself automagically.
  • 01-11-2009 4:37 PM In reply to
    • Bieele
    • Netherlands
    • Posts 339
    Re: New Beosystem 3
    PhilLondon:
    Regards, Robert
    That seems to make sense; very useful feature, that can improve sound quality in many cases. Furthermore this would explain the need to make some hardware changes and also a lot of other brand (high end) processors have this feature.
    Bieele
  • 05-11-2009 2:20 PM In reply to
    Re: New Beosystem 3
    I just contacted B&O via online form.
    The BeoSystem 3 MK II is already mentioned in their menu (Video --> BeoSystem --> MK II. Curious what's new...
  • 05-11-2009 2:50 PM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    Re: New Beosystem 3
    How do you know that's the MKII? Specs seem the same as before?
  • 05-11-2009 2:59 PM In reply to
    Re: New Beosystem 3
    If you go to "Contact us" on the B&O site I selected under Product category Video ---> BeoSystem3 and then you can choose between MKI and MKII...
    I don't know how to post a screenshot!
  • 05-11-2009 3:36 PM In reply to
    • MikaelB
    • Joined on 04-17-2007
    • Herning, Denmark
    • Posts 191
    Re: New Beosystem 3
    In Danish - but you get the mening
  • 05-12-2009 9:52 PM In reply to
    • Corvin
    • Australia
    • Posts 124
    Re: New Beosystem 3
    I can't find this on the English version but also wish to know the specs of the new BeoSystem 3.
  • 05-13-2009 4:30 AM In reply to
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    Re: New Beosystem 3
    It also appears on the french version : this seems to confirm that some important changes will be made on the BS3, otherwise the FAQ would not have been different. Really interesting!
  • 05-15-2009 6:15 PM In reply to
    • Alex
    • New York, NY
    • Posts 176
    Re: New Beosystem 3
    It's a RAM update necessary for the new AST and that's it!
    I have one in my store ... there's absolutely no difference besides the extra RAM and maybe some different internal components.  Also, just as an FYI "older" units can be retrofitted.
  • 05-16-2009 8:25 AM In reply to
    Re: New Beosystem 3
    Is it also possible to retrofit a BV7 MKIII?  Does AST function once the extra RAM and internal components are fitted?
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 05-19-2009 12:00 PM In reply to
    • Alex
    • New York, NY
    • Posts 176
    Re: New Beosystem 3
    Razlaw:
    No ... the AST function is going to be enabled on a future software update.  As of right now it's still greyed out in the menu.
    Also, as far as I know any BeoSystem 3 based product should be upgradeable.
  • 05-19-2009 12:01 PM In reply to
    • Alex
    • New York, NY
    • Posts 176
    Re: New Beosystem 3
    Razlaw:
