I have a DVD 1 connected to my MX 8000 TV.
The DVD 1 player works Ok when I use the control buttons on its front panel. I am also able to start playing using the GO button on my Beo 4 remote control.
Here is my problem: When opening up the menu using the BLUE button or the MENU button, I cannot navigate. If I use the << or >> button, the DVD starts a fast rewind or forward, respectively. It is simply impossible to navigate horizontally between menus, and it is also impossible to navigate vertically, within one menu using the ^ and v buttons.
I have also tried the DVD 1 with my MX 7000 TV. Same result.
I changed to a different SCART cable, but that did not help.
And I tried with different remote controls.
Can anyone help me figure out what is wrong?
