Latest post 01-18-2009 4:48 AM by mr_anders_son. 3 replies.
Page 1 of 1 (4 items)
  • 12-20-2008 1:42 PM
    • magmy
    • Not Ranked
    • Joined on 12-20-2008
    • Posts 2
    Cannot navigate DVD1 menu
    I have a DVD 1 connected to my MX 8000 TV.
    The DVD 1 player works Ok when I use the control buttons on its front panel. I am also able to start playing using the GO button on my Beo 4 remote control.
    Here is my problem: When opening up the menu using the BLUE button or the MENU button, I cannot navigate. If I use the << or >> button, the DVD starts a fast rewind or forward, respectively. It is simply impossible to navigate horizontally between menus, and it is also impossible to navigate vertically, within one menu using the ^ and v buttons.
    I have also tried the DVD 1 with my MX 7000 TV. Same result.
    I changed to a different SCART cable, but that did not help.
    And I tried with different remote controls.
    Can anyone help me figure out what is wrong?
  • 12-21-2008 6:00 AM In reply to
    Re: Cannot navigate DVD1 menu
     i have the same hardware: MX8000 and DVD1, here it works perfect.
    Ähmmm, how is the AV Port configurated: CDV alias DVD or VTape?
    Menu - Options - Sockets ...
    VTAPE = Vtape.....= AV1
    AV = DVD....... = AV2
  • 12-21-2008 3:52 PM In reply to
    • magmy
    • Not Ranked
    • Posts 2
    Thanks for taking the time to answer.
    I just re-checked my connections using my MX 7000 TV and just the DVD 1 player (no V.TAPE connected).
    Here are my settings:
    • AV1 = None
    • AV2 = CDV
    Just the way you describe it.
  • 01-18-2009 4:48 AM In reply to
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
