Hello,
I recently got a MKII ( 2006 or 2007 ) DVD1 and I don't think it's working properly. It's from the UK, but I got an EU plug and the B&O scart cable from my dealer here.
When I insert a DVD it has an annoying lag when choosing DVD menu options. But I can live with that. The problem is, that it does not respond when I press GO, to select any of the dvd menu options. In some cases it does work, but only to access the submenus, and that takes ages to happen. Update: I've just noticed it works if I press GO twice instead of once. Also, the blue button that is supposed to bring up the toolbar doesn't work like described, it only shows ( again, only if pressed twice ) the Angle menu option. It also won't fast forward.
When I do manage to get a film to play, the picture is windowboxed, even thought I've set the video output as 16:9 ( Wide ), it just pops it back to 4:3/windowboxed the next time I start it ( but it still shows as 16:9 in the "initial Settings > Video Output menu ) - the TV is a BeoVision 3-32 and it's a couple of years older than the DVD ( could this be the problem? ).
And there is another thing that puzzles me, but it's nothing really important. If I'm watching a DVD and I decide to turn it off and therefore press the little red dot button, it will not only turn off the DVD1, but also the TV. Can something be done about this?
PS. The menus are ugly, nothing like B&O and actually nothing like in the User Manual ( is it only for the MK I versions? ). Is that a bad sign? Is there a way to do  complete hard reset and configure it all over again (regions, picture settings,... etc. )
Thanks for your help.
