Latest post 01-26-2009 4:57 PM by tournedos. 9 replies.
Page 1 of 1 (10 items)
  • 11-28-2008 8:26 AM
    • Nis
    • Not Ranked
    • Joined on 08-13-2008
    • Roskilde, Denmark
    • Posts 30
    Which speakers have connection for Beovox 2500 Cube?
    Hi all,
    Is there a list of which Beovox speakers have connection for Beovox 2500 Cube?
    If not, I suggest we try to build such a list.
    Best regards
    Nis
    Filed under:
  • 11-28-2008 11:30 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Which speakers have connection for Beovox 2500 Cube?
    As far as I know there are the Beovox 5000, Beovox 4000 and Beovox 3000
    Chris.
  • 11-29-2008 4:00 AM In reply to
    Add Beovox 1500 to that list.
  • 11-29-2008 12:45 PM In reply to
    You can of course just run them off the speaker 2 sockets of the Beomaster. You can therefore use them with any speakers.
  • 11-30-2008 6:40 AM In reply to
    Sure abt that ??, Do the cubes contain the filter or do they make use of the filter section in the box ?
    If they don't have any filter build in, i don't think connecting them direct to the amp is a good idea...
  • 11-30-2008 7:38 AM In reply to
    AFAIK there's a cap in series, so the cubes effectively have the tweeter part of a simple two-way crossover built in and it's safe to run them directly from the amp.
    -mika
  • 11-30-2008 9:09 AM In reply to
    The out let has a swtichover conacts, it turns off the onboard speaker tweeters, if you simply connect inline you will not do this.
    As for a disadavantage, that would depend on if you site your cubes to a slightly differant location to the main speakers, becuase then you'll have too many tweeters and the image will be less well defined
  • 01-13-2009 2:56 AM In reply to
    • Nis
    • Not Ranked
    • Roskilde, Denmark
    • Posts 30
  • 01-26-2009 4:29 PM In reply to
    • Xseries
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Hampshire
    • Posts 433
    If you look back at an early 1960s catalogue I have they are actually shown as the speakers of choice for the Beomaster 900K to enhance the stereo separation!
    Brian
  • 01-26-2009 4:57 PM In reply to
    Xseries:
    Brian
    And probably to a great benefit! I have found the built-in speakers in 900K to be too directional. The sound (and stereo image) are great when you're listening at a distance, accurately at the same hight as the receiver, and not too far off axis... otherwise, you usually have to turn the bass way down - and treble up - to keep the sound balanced.
    -mika
