Latest post 11-16-2008 5:57 PM by KingOfSnake. 10 replies.
Page 1 of 1 (11 items)
  • 11-15-2008 1:53 PM
    problem with BeoVision 7-40 (DVI and Component) with Playstation 3
    Can anyone help me - I have a PS3 (Playstation 3) and a BeoVision 7-40(with HD upgrade-kit).
    First I tried to use HDMI - DVI cable - but no picture.
    I bought a component cable (YPbPr) and tried but no picture..
    These are my setting in my B&O TV.
    AV1:
    DVD2
    HDTV: DVI-I (and I have also tried YPbPr)
    If I connect my Playstation in the CAMERA connection at side of the tv with s-video cable it works - but I want to have HD...
    Anyone with ideas ?!
    thanks !
  • 11-15-2008 3:48 PM In reply to
    Re: problem with BeoVision 7-40 (DVI and Component) with Playstation 3
    http://www.sony.co.uk/hub/bravia
    popgear is grate™
  • 11-15-2008 4:13 PM In reply to
    don't understand where to look at that site... please what do you mean ?!
  • 11-15-2008 4:21 PM In reply to
    OK here's how.
    1) Connect PS3 via composite or scart adaptor so you can see the screen, picture quality poor but there you go - i.e. set sw to AV2, source as dvd2 and no HD - you simply want the ps3 image and access to the menus.
    2) Choose DISPLAY SETTINGS on the PS3 menu
    3) Choose Output medium as Component
    4) Says SCREEN WILL GO BLANK FOR 30 SECS ETC - PRESS X to begin
    5) Best thing to do is have the Component leads already connected to the BV7, usually on AV4 and sw settings to PC or V.MEM
    6)Presss X
    7) disconnect the lead from composite/scart adaptor at ps3 end and put in component lead end (into PS3)
    8) Press V.MEM or PC on BEO4 (whichever you chose to identify ps3 by)
    9) Press X on PS3
    Clear as mud?  But it works...........................  all this from an £8000+ set,  but after you've done this you'll be over the moon.
  • 11-15-2008 6:05 PM In reply to
    thanks !
     But how will i get 5.1 surround sound when I use component ?!
  • 11-15-2008 6:38 PM In reply to
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    im sure the ps3 has a digital output that you can connect to the tv and assign a sound device to the relevant av connections menu for DD
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 11-15-2008 7:26 PM In reply to
    PS3 has a Toslink (digital connection) but Not my tv... do I have to use some kind of adaptor ?!
  • 11-15-2008 10:26 PM In reply to
    Yes you need an optical to digital coax converter - with leads about £25, be sure to set the sound output settingts to Dolby Digital - I suggested AV4 because (usually) the component leads come with stereo letft and right phono.  So you've got ghe picture working?
  • 11-16-2008 2:29 PM In reply to
    OK - converter will solve my problem !
    Yes - now I have picture ! Thanks for your help !
  • 11-16-2008 2:32 PM In reply to
  • 11-16-2008 5:57 PM In reply to
    KingOfSnake:
    OK here's how.
    6)Presss X
    9) Press X on PS3
    Solved like this I assume!
