1st March February 2012
Latest post 02-01-2009 8:21 AM by stefan. 104 replies.
Russ
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.32.14/avatar.jpg)
![Top 100 Contributor Top 100 Contributor](/Themes/beotheme1/images/rankicons/rankTop100.gif)
![Male Male](/Themes/beotheme1/images/rankicons/GenderMale.gif)
- Joined on 05-07-2007
- Washington, DC USA
- Posts 641
![Bronze Member](/Themes/beotheme1/images/roleicons/8373aae9-2be6-4a12-8c67-ab927ce1557e.gif)
TripEnglish:I don't know, SP. I'm still a little worried about jitter.
No need to feel 'jittery' Trip!
We kid because we love.
Bang & Olufsen Tysons Galleria
McLean, VA USA
PhilLondon
![](/utility/anonymous.gif)
![Top 25 Contributor Top 25 Contributor](/Themes/beotheme1/images/rankicons/rankTop25.gif)
- Joined on 04-16-2007
- London
- Posts 2,545
![Founder](/Themes/beotheme1/images/roleicons/6f51347a-6d4c-4ff4-9d2e-4e3705076d55.gif)
Beosound 5 is connected to the Beomaster 5 via a USB, a DVI and a special power cable. The Beomaster 5 can also be connected to the TV via HDMI and ML.. The Beosound 5 allow you to browse through your N.MUSIC and N.RADIO, on its own screen. The Beosound 5's screen is not meant to display media. It is just a user interface which allow browsing. It shows CD cover. You can use the Beomaster through the TV screen to navigate with the Beo4 through your N.MUSIC and N.RADIO, but also through Video, Photo and Web, like on the old Beomedia 1.
PhilLondon
- London
- Posts 2,545
Like a Beomedia... with a TV that is compatible with the PC source. p.
Russ
- Posts 641
OKF, ML does not handle video in any set-up so, no, it is not sufficient in itself. BeoMaster 5 will likely use the 'PC' command on modern B&O TV's, so I would expect to use a 15-pin VGA cable for video. For video, it will also output DVI-I, S-video, and composite video.
McLean, VA USA
stefan
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.99/avatar.jpg)
![Top 50 Contributor Top 50 Contributor](/Themes/beotheme1/images/rankicons/rankTop50.gif)
- 200 miles from Struer
- Posts 1,733
Beomaster 5 will be controlled via Masterlink with PC command, video via DVI and composite, audio via spdif and analogue. You will find this information and much more - complete user- and service manuals for Beomaster 5 AND Beosound 5 - here: http://www.beoworld.org/manuals.asp Stefan
jk1002
![](http://idisk.mac.com/jkalter-Public/bug.gif)
- Boston USA
- Posts 1,620
With Silver Membership you should be able to get there, you might have to send Lee a note. Cheers JK
OKF
![Top 500 Contributor Top 500 Contributor](/Themes/beotheme1/images/rankicons/rankTop500.gif)
- Joined on 02-22-2008
- Posts 204
Thanks, yes I have it now and new questions arise :-) My BV 7-40 does have a DVI-I Port and I guess it is active. Does this Port transport sound and video signals? I have connected to the PrPbY and to audio R/L a Wii Station. In that resperct I am not sure whether my 7-40 is HD ready or not. Looking at the Product No. which ends with 51 it is MK1 but from 2006 which should be MK 2 and I need to find out the differences.
PhilLondon
- London
- Posts 2,545
DVI does not transport sound, so you will have to connect the sound connection using a separate cable can configure it in the menu. Only HDMI has sound. I suggest now that you are a member that you run the PCG every time you connect something as it will tell you how to connect it the best. p.
OKF
- Posts 204
The PCG is not really that comfortable and it does not include the BS5 How is sound transported from BS5 respectively the BS5 main Box, just by ML? Or is it the Line (one plug?) out and where does line out go to into the BV7-40?
Mr10Percent
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.22.04/avatar.jpg)
![Top 150 Contributor Top 150 Contributor](/Themes/beotheme1/images/rankicons/rankTop150.gif)
- In Transit
- Posts 441
Well I thought HMDI 1.9xx, 2.5xx, then 6.7xx were the future proof (non-backward compatable) connection standards that everyone harped on about and demanded to have in every B&O product! When are we all going to realise most of this stuff is gimmick for the far-Eastern electronic companies to sell us the same stuff. No-doubt DisplayPort will be another compatability nightmare (I know what it promises - but so did HMDI) and digital rights management censorship. May it not last long. 10%
PhilLondon
- London
- Posts 2,545
Thanks a lot. Worked fine of vista. BV7 "TV" has been added. Was hoping to see BM5/BS5....
OKF
- Posts 204
How can I convert? Baut it does not solve the sound Problem I guess.
