Latest post 02-01-2009 8:21 AM by stefan. 104 replies.
Page 4 of 5 (105 items) < Previous 1 2 3 4 5 Next >
  • 12-20-2008 11:34 PM In reply to
    Re: Beosound 5 specs
    I don't know, SP. I'm still a little worried about jitter.
    There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
  • 12-26-2008 2:15 PM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    TripEnglish:
    No need to feel 'jittery' Trip!
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 01-06-2009 10:15 AM In reply to
    • OKF
    • Top 500 Contributor
    • Joined on 02-22-2008
    • Posts 204
    I still do not quite understand the layout. The Beosound5 is a control panel. Is that linked to the Beomaster5 by a cable or is it wireless? Where do you have to position the 2 units? Is the connection just the ML or do have to connect it to the TV when you want to see pics? It is equipped with wireless, is that for internet access?
    Best regards Oliver
  • 01-06-2009 10:34 AM In reply to
    Beosound 5 is connected to the Beomaster 5 via a USB, a DVI and a special power cable.
    The Beomaster 5 can also be connected to the TV via HDMI and ML..
    The Beosound 5 allow you to browse through your N.MUSIC and N.RADIO, on its own screen.
    The Beosound 5's screen is not meant to display media. It is just a user interface which allow browsing. It shows CD cover.
    You can use the Beomaster through the TV screen to navigate with the Beo4 through your N.MUSIC and N.RADIO, but also through Video, Photo and Web, like on the old Beomedia 1.
  • 01-07-2009 8:08 AM In reply to
    • OKF
    • Posts 204
    When the Beomaster is connected to the TV will it work propperly when only connected via ML and also show pics and full bowsing funcionality?
    Best regards Oliver
  • 01-07-2009 8:12 AM In reply to
    Like a Beomedia... with a TV that is compatible with the PC source.
    p.
  • 01-07-2009 9:30 AM In reply to
    • OKF
    • Posts 204
    I do not know how beomedia works, so it does not answer the question how to conect to the TV and wether ML as a connection will be sufficient?
    Best regards Oliver
  • 01-07-2009 10:00 AM In reply to
    • Russ
    • Posts 641
    OKF,
    ML does not handle video in any set-up so, no, it is not sufficient in itself.  BeoMaster 5 will likely use the 'PC' command on modern B&O TV's, so I would expect to use a 15-pin VGA cable for video.  For video, it will also output DVI-I, S-video, and composite video.
    McLean, VA USA
  • 01-07-2009 10:09 AM In reply to
    • OKF
    • Posts 204
    Thanks a lot so it would mean to put an anying black box somewhere near the BV 7. B+O does not have brain in gear.
    Best regards Oliver
  • 01-07-2009 10:12 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Beomaster 5 will be controlled via Masterlink with PC command, video via DVI and composite, audio via spdif and analogue.
    You will find this information and much more - complete user- and service manuals for Beomaster 5 AND Beosound 5 - here:
    http://www.beoworld.org/manuals.asp
    Stefan
  • 01-07-2009 10:13 AM In reply to
    ...and these cables can be pretty long...
  • 01-07-2009 10:20 AM In reply to
    • OKF
    • Posts 204
    I have no access to this part of the site
    Best regards Oliver
  • 01-07-2009 4:56 PM In reply to
    With Silver Membership you should be able to get there, you might have to send Lee a note.
    Cheers
    JK
  • 01-07-2009 5:36 PM In reply to
    OKF did not have his membership at the time he wrote his previous post. He is now one of us (!) and can download the manuals...
  • 01-09-2009 7:06 AM In reply to
    • OKF
    • Posts 204
    Thanks, yes I have it now and new questions arise :-)
    My BV 7-40 does have a DVI-I Port and I guess it is active. Does this Port transport sound and video signals? I have connected to the PrPbY and to audio R/L a Wii Station. In that resperct I am not sure whether my 7-40 is HD ready or not. Looking at the Product No. which ends with 51 it is MK1 but from 2006 which should be MK 2 and I need to find out the differences.
    Best regards Oliver
  • 01-09-2009 7:14 AM In reply to
    DVI does not transport sound, so you will have to connect the sound connection using a separate cable can configure it in the menu.
    Only HDMI has sound.
    I suggest now that you are a member that you run the PCG every time you connect something as it will tell you how to connect it the best.
    p.
  • 01-09-2009 8:04 AM In reply to
    • OKF
    • Posts 204
    The PCG is not really that comfortable and it does not include the BS5
    How is sound transported from BS5 respectively the BS5 main Box, just by ML? Or is it the Line (one plug?) out and where does line out go to into the BV7-40?
    Best regards Oliver
  • 01-10-2009 6:56 PM In reply to
    • mor
    • Joined on 04-19-2007
    • Cologne
    • Posts 104
    Actually both HDMI and DisplayPort support sound (DVI does not) HDMI already appears as a technology that'll be phased out mid-term.
  • 01-10-2009 11:15 PM In reply to
    Well I thought HMDI 1.9xx, 2.5xx, then 6.7xx were the future proof (non-backward compatable) connection standards that everyone harped on about and demanded to have in every B&O product!
    When are we all going to realise most of this stuff is gimmick for the far-Eastern electronic companies to sell us the same stuff.
    No-doubt DisplayPort will be another compatability nightmare (I know what it promises - but so did HMDI) and digital rights management censorship.
    May it not last long.
    10%
  • 01-11-2009 4:07 AM In reply to
    Latest Product Configuration Guide is now on. Can someone check it is working! I have zipped it on a Mac so cannot check it here! Laughing
  • 01-11-2009 4:26 AM In reply to
    Thanks a lot. Worked fine of vista.
    BV7 "TV" has been added. Was hoping to see BM5/BS5....
  • 01-11-2009 4:54 AM In reply to
    I am sure we will add it once it is on!
  • 01-11-2009 7:23 AM In reply to
    • OKF
    • Posts 204
    I have an MK1 so no HDMI just normal DVI I Port....
    Best regards Oliver
  • 01-11-2009 8:35 AM In reply to
    OKF:
    You can convert from DVI to HDMI. Converters are quite cheap. You still need to get the sound with separate connection.
  • 01-11-2009 1:42 PM In reply to
    • OKF
    • Posts 204
    How can I convert?
    Baut it does not solve the sound Problem I guess.
    Best regards Oliver
