Hello. The Century comes with a detachable handle-***-aerial, held in place by two screws. I detached mine years ago, and now want to replace it. I'm not certain if I have the right screws! The two I've found are black, flat-ended and measure 27.0 mm x 2.5 mm. Can someone confirm that these are the correct ones? Thank you. (I promise to sellotape them to the handle, if I remove them again!)
Matthew.
