Latest post 10-01-2008 5:48 AM by MatthewWilde. 2 replies.
Page 1 of 1 (3 items)
  • 09-30-2008 6:55 AM
    Century - handle screw dimensions?
    Hello.  The Century comes with a detachable handle-***-aerial, held in place by two screws.  I detached mine years ago, and now want to replace it.  I'm not certain if I have the right screws!  The two I've found are black, flat-ended and measure 27.0 mm x 2.5 mm.  Can someone confirm that these are the correct ones?  Thank you.  (I promise to sellotape them to the handle, if I remove them again!)
    Matthew.
  • 09-30-2008 8:53 AM In reply to
    Re: Century - handle screw dimensions?
    Hi Matthew,
    the dimensions you give are broadly right (27.27mm x 2.78mm).  Here is a picture of one of the scres.  The head is slightly domed, with a single slot for screwdriver but will also take a 10mm hex driver.  In the middle of my heads there is a brass coloured centre with a small hole drilled in it (part of the machining I'm guessing.
    Dave
    Am I ready? I was born ready!
  • 10-01-2008 5:48 AM In reply to
    Many thanks, Dave, for a very helpful answer.  Problem solved!
    Matthew.
