Latest post 01-15-2009 5:55 AM by Keith Saunders. 9 replies.
Page 1 of 1 (10 items)
  • 06-01-2008 5:07 PM
    • tIRED
    • Not Ranked
    • Joined on 05-27-2008
    • Posts 32
    Popcorn Hour A-100 Media Tank - When will is be included in the PUC-list?
    Does anyone (with BO relations) have a clue on this one? I recently bought a couple of these for my TV-setups and it is simply astonishing! This is the kind of media player BO should have in thier on product portfolio (and then charge 10 times the USD 200 price I paid). Would love to see it in PUC-list sometime really soon! Please BO - serve your customers (for once)..
    /tIRED (of my corrupt $100.000 setup)
  • 06-02-2008 12:49 AM In reply to
    Re: Popcorn Hour A-100 Media Tank - When will is be included in the PUC-list?
    Your dealer who sold you your 100K system can create a PUC for you for very few $ more :0)
    I think there are quite a few of these devices, unless it has volume in sales as like an Apple TV has I doubt they will add it on their own. And even if they do, you would still have to get your software updatded. It really is not that difficult to create a PUC it seems so I would I ask.
    Cheers
    JK
  • 06-02-2008 5:19 AM In reply to
    • tIRED
    • Not Ranked
    • Posts 32
    I've offered to send a sample box to them (which they can send to BO). They said it was just a matter of waiting (and hope that more people request this upgrade)... I have three BV7-40 (and thress A-100 boxes) so I would gladly pay some money to get it done..
    I believe they have shipped some 1.000.000 units by now (6 months after release) so you couldn't really call it a "nisch" product anymore. I fully understand thier success in sales though, wonderfull box!
  • 08-02-2008 4:55 AM In reply to
    Has anyone managed to get beo5 controll the Popcorn hour???
  • 11-25-2008 6:20 AM In reply to
    I've just bought the A-110, as anyone go the PUK sorted for the 100 or the 110?
    Beosystem 3, Beosound 4, Beolab 9, Beolab 3, Beolab 8000
  • 11-25-2008 2:46 PM In reply to
    In the next couple of days I will be adding the POPcorn Hour A100 XML file for the Beo5 to the downloads
    Regards Keith....
  • 11-25-2008 4:23 PM In reply to
    • tIRED
    • Not Ranked
    • Posts 32
    What good would this do? I don't have Beo5:s but as I understand it they only communicated with the BO-equipment and does not act as a "programmable remote"!? Is this wrong? I was told (by my dealer) that before BO makes a PUC-table for the unit I cannot control it no matter what remote I get...
    Filed under:
  • 11-26-2008 2:15 AM In reply to
    tIRED:
    With the Beo5 you can control any third party product without using the PUC. Some products it is still better to control via the PUC, but that does not mean they have to be.
    In fact in future ALL templates produce by B&O for the PUC will also be available for the Beo5. The data contained in the PUC table is in fact the very same basic data used in the BEO5 product files
    Regards Keith....
  • 01-15-2009 5:39 AM In reply to
    do anyone know if there is (in the meantime) the possibilty to use BEO4 as remote control for Popcorn A-100 / A-110?
    BR
    Joe
  • 01-15-2009 5:55 AM In reply to
    As the Popcorn A-100/A-110 is not in the PUC you can either:-
    • Control it using as Beo5 or;
    • Use a Lintronic converter box to map Beo4 codes to Popcorn IR codes
    Regards Keith....
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
