1st March February 2012
Latest post 03-10-2011 5:54 PM by pavur. 66 replies.
Stan
- Joined on 04-17-2007
- Posts 593
Re: Beolink Active - PC Input
amunk: Hi, Excuse me for my ignorance but what can be achieved with this solution? As I read it I can connect som third-party equipment to the Beolink Active. Can the audio for this source then be distributed on the Masterlink? Thanks in advance. Regards, Anders
This does not distribute audio on ML, but it does allow one to share one's ML'd active speakers with a non-B&O source. For example, I have a non-B&O TV in a link room with BL4000s and an active. With this cable, I will be able to connect my TV to the speakers, and either listen to the ML audio or the local TV audio. Stan
beoaus
- Joined on 04-16-2007
- Melbourne, Australia
- Posts 445
I thought I saw a reply to this message... The cable allows audio to be connected to the PC Input. The PC command allows that local audio signal to played through the speakers connected to the Beolink Active. The audio source is not available to other link rooms. Very useful. You can connect a TV with Line out, a Turntable, IPod, etc.... Beoaus.
Hagen2000
- Joined on 05-08-2007
- Munich
- Posts 267
Hi beoaus, is it possible that you determine the connections of the adapter cable, i.e. which pins are connected?
beoaus
- Posts 445
Hagen2000: Hi beoaus, is it possible that you determine the connections of the adapter cable, i.e. which pins are connected?
Cable is buried in the wall... I'll get it out this weekend. Not sure how to open the DIN section of the cable without wrecking it... There is a tab to push but the cover does not slide back. Any suggestions?
11048437
- Posts 352
beoaus: Hagen2000: Hi beoaus, is it possible that you determine the connections of the adapter cable, i.e. which pins are connected?
beoaus, there is no necessary to open the DIN. A multimeter is the solution. In case you do not have one, get one - it's only few dollars- . It's always a good ideea to have one around to check voltage, etc....
11048437
- Posts 352
Hagen2000
- Munich
- Posts 267
Hi beoaus, you might also want to test if there are bridges / interconnections in the DIN plug.
beoaus
- Posts 445
Ok, I'll get a multimeter and try to learn something. I figure I'm ok with checking pins though I'm not sure about these bridges and like. Any tips?
11048437
- Posts 352
hi guys.... finally, I can confirm that the DIN cable for the PC input on the beolink active has : pin5 - right(left) in channel pin2 - left(right) in channel pin6 - ground regards....
beoaus
- Posts 445
11048437: hi guys.... finally, I can confirm that the DIN cable for the PC input on the beolink active has : pin5 - right(left) in channel pin2 - left(right) in channel pin6 - ground regards....
Does that save me lifting the TV off the wall again?
11048437
- Posts 352
beoaus: 11048437: hi guys.... finally, I can confirm that the DIN cable for the PC input on the beolink active has : pin5 - right(left) in channel pin2 - left(right) in channel pin6 - ground regards....
yep!.....I have made this cable yesterday and it's working(cost me only 2$). It was necessary to connect my Beolab 3 speakers to the Panasonic HDD-DVD recorder in my bedroom vis Beolink Active box! Now, everything is perfect....
Stan
- Posts 593
I have finally obtained the correct cable, and it all works as expected (both channels, no mixing of ML audio). Thanks again Beoaus and everybody else that has contributed to this thread. San
beoaus
- Posts 445
Good to see.... Happy we have the cable sorted. It's very useful information. Perhaps the cable spec could be listed somewhere, even part of the BeoLink Active product information, FAQ or Beocentral... cheers, beoaus.
cdj
- Joined on 08-06-2008
- Posts 3
Hi, I did already use the PC input on a Beolink Active. The pins used are not the same as the Powerlink. If ever you do not want to order the cable in the USA, this is how I did it : I did solder my cable by myself. Just put a Din connector in and test with a srewdriver to find the left and right channel. then test to fond the ground. After this you can solder the cable to it and use your auxilary input.
Heribert
- Joined on 08-06-2009
- Austria
- Posts 592
Dear all,
I learned a lot reading this thread but at the end I realised the Beolink active which sounded very well is not a solution for my problem.
I have a BL2000 in a link room and also a Toshiba LCD with SAT Receiver. Now I want to bring Toshiba sound to my BL2000. I thought BL-active can help but as I learned now that it does not distribute Sound over ML. Is there any other solution to use my BL2000 with the Toshiba LCD?
btw: I have ML available in this room, the BL2000 is working now stand alone.
Heribert
BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 / Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
PhilLondon
- London
- Posts 2,545
Heribert,
What Hifi and TV have you got in the main room?
Heribert
- Austria
- Posts 592
Hi Phil,
I have a BV-8-40 with BS3200 and BL3. On ML there is also a Beoport with my Mac connected. The Toshiba LCD and BL2000 are in the Saunarium in first level - thus I cannot easily connect Toshiba LCD to BV8 od BS3200
Thanks,
Heribert
Stan
- Posts 593
If your Beoport is near the TV, you could run the audio from the TV through a splitter into the Beoport (so both the computer's audio and TV's audio go into the Beoport). Then, to listen to the TV, you select N.Music, and stop iTunes.
I do this with my turntable... it's kind of a pain, but does do the job.
Stan
Heribert
- Austria
- Posts 592
Beoport is in a different room with just ML or Ethernet connection to Link Room with Toshiba LCD or Main Room.
But Thanks Stan.
Heribert
elephant
- Posts 2,215
Stan:
So Stan to confirm your implication, the BeoPort lacks the Active's "PC" or alternative source capability ?
A pity, because I would like to have the ability to listen to and operate the BeoPort with out a PC/Mac being present
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
Stan
- Posts 593
elephant:
Stan:
Yes, the BeoPort *must* be connected to a computer.
PhilLondon
- London
- Posts 2,545
Stan:I do this with my turntable... it's kind of a pain, but does do the job.
Stan, I have just built a feature in LinkPlayer that will solve your problem ;-) Check sometime next week when beta 0.8 is released.
p.
ouverture
- Joined on 04-20-2007
- London
- Posts 282
do you mean a feature where it will work without a MacBook being connected to the Beoport Phil ??
PhilLondon
- London
- Posts 2,545
ouverture:a feature where it will work without a MacBook being connected to the Beoport Phil
No, that will not be possible as it is due to the firmware of the box...
I meant a feature to allow access to (and distribution of) an analog source in the room in addition to N.MUSIC and N.RADIO.
