 elephant:
 elephant:
my BeoLink Active manual says that there is a manual for covering the attachment of devices to the PC port on the new model of the BeoLink Active
This passage refers to "a relict of the past"
- to the BeoLink PC Office, not to BeoLink PC2/BeoPort:
*The socket marked PC is used in BeoLink PC setups only. Please
refer to the User’s guide enclosed with the BeoLink PC kit.
Explanation:
Beolink PC Office had no PL Sockets and needed a BeoLink Aktive Upd 1636
(introduced 1999) to connect to active speakers.
The previous version of BeoLink Aktive 1616 (before 1999) had 2 PL sockets
therefore B&O had to cancel one PL socket to make way for the PC socket.
For safety reasons they "invented" the crazy pin-config I have described several times ...
"PC-Socket" on BeoLink Active 1636 - pin configuration - Source: BeoWise
1. SL-config
2. LEFT IN
3. Left out
4. RIGHT IN
5. Right out
6. Data -
7. GROUND / SHIELD
8. Data +
The PC-Office manual says:
…to your PC
Use the BeoLink PC cable box:
• Connect the appropriate plug to a free serial
COM port on your PC. If a 25 pin plug is
required, use a serial 9/25 pin adaptor.
• Connect the plug marked SOUND OUT to
the socket LINE OUT on the Sound card on
the back of your PC. If no LINE OUT socket is
available, use the speaker out socket instead
(SPK OUT).
• Connect the appropriate plug to the socket
marked PC on the BeoLink Active box.
The attached picture of a vintage PC Office shows the cable clearly
(but won't help you)
Solution:
Ask your dealer to rewire the faulty adaptor cable from pin 2/5/6 wiring
to the correct pin 2/4/7 configuration:
2. LEFT IN
4. RIGHT IN
7. GROUND / SHIELD
It's not a big issue when you have access to a soldering iron ...
PS: to all BeoLink 1000  devotees  "PC" = "SHIFT"+"STORE"
