Hello,
I just bought an Ouverture from overseas, and just my luck, the CD don't seem to work. Tape and radio are OK, as far as I tested.
I press load and the arm rises nice, and I can place a CD on its place, face up, of course. Then pressing either load or CD closes the arm, but the CD does not turn. Pressing CD again and listening very close, I can hear a slight humming sound for about 3 secs, still the CD do not move and the display shows "CD <>" after a while.
Is it the CD mechanism, or am I missing something?
I found a mention about loosening a transport screw, but I do not find one. I do not have the setup guide, where this is told, I think.
What would be the cost of the CD mechanism? Anyone had one changed?
Cheers,
Pekka
