1st March February 2012
Latest post 06-04-2010 4:32 PM by Craig. 8 replies.
06-02-2010 4:59 AM
agerrard
- Joined on 12-15-2008
- Posts 5
What remote control do I need for a BeoVision?
I've got a BeoVision Avant and a MX4002, and one of the Beo4 remote controls has died - kids & coffee :-( So I need to get a replacement for one or other of the tellys - do I need to just get another straight-forward replacement Beo4, or are there alternatives that can be used? And are there any compatibility issues that I need to be aware of? Does anybody have any suggestions as to what I should be looking for?
Thanks.
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
Re: What remote control do I need for a MX4002?
You can use a Beolink 1000, usually half the price used compared to used Beo4.
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
Peter
- Joined on 02-12-2007
- Posts 9,572
I agree though a Beo5 would be another option if you want a new toy for the Avant. Useful if you use satellite and have an audio system as well though it does take a little getting used to. The Beolink 1000 is excellent and is also child proof! Some functions will need learning though and if you have a linked VCR to the 4002 some of the controls may not be quite as easy as the Beo4 that you are used to.
gk31ax
- Joined on 04-18-2007
- Posts 220
I agree with Peter, the Beo 5 does take some getting used to, I still reach for the 4 to be honest!!
agerrard
- Posts 5
Thanks for the suggestion - I hadn't considered the Beolink 1000 as an option.
agerrard
- Posts 5
Thanks for the reply - the Beo5 might be too much for what I need right now, so the Beolink 1000 or a Beo4 will probably be my choice.
agerrard
- Posts 5
That confirms Peter's view, many thanks - so it's a choice between a straight Beo4 replacement or a Beolink 1000.
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Do be aware, that the Beo4 your kids killed, may well be repapirable!
Andy T.
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Where are you as I have a Beolink 1000 for slae at the moment?
Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Page 1 of 1 (9 items)
