1st March February 2012
Latest post 05-08-2007 10:05 PM by SWISS_2. 20 replies.
05-08-2007 2:11 AM
kijf001
- Joined on 04-27-2007
- Posts 10
Difference beolink pc2 and beoport
Hi there, is there someone who can explain what the difference is between beolink pc2 and beoport? thanks in advance
djjkroon
- Joined on 04-18-2007
- Uddel, the Netherlands
- Posts 113
Re: Difference beolink pc2 and beoport
Yep, I will try, there are none. Only the name;)
Muzies,
Hans Kroon
kijf001
- Posts 10
Thanks for the quick answering. then i will buy a secondhand beolink pc2. cheers
beo4me
- Joined on 04-17-2007
- Posts 175
What about PC office and Beoport? I heard that PC Office could play with the PC switched off, something the Beoport (and possibly PC2) can not do.
Cheers, Frank
Coolskin
- Joined on 04-16-2007
- Holland
- Posts 505
djjkroon: Yep, I will try, there are none. Only the name;)
Correction. In daily use you don't see any difference between Beolink PC2 and the Beoport. The first Beoport boxes even state Beolink PC2 on the side. But the Beoport has an improved printed circuit board.
djjkroon
- Posts 113
Thanks, that's right I have a BeoPort saying PC2.
Muzies,
Hans Kroon
B&Ola
- Posts 302
What is the latest firmware on PC2/Beoport?
/Ola
Alex
- Joined on 04-23-2007
- Posts 223
Can I use the Beoport in my home-office with my Windows powered PC and by plugging in my Beolab 8k ? Can it act like a "master" ?
PhilLondon
- London
- Posts 2,545
You can update both to the same latest firmware, and it is easy to do, so go for a pc2 without problem. p.
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
B&Ola: What is the latest firmware on PC2/Beoport?
/Ola
Hola, Ola! It's 9.1.0.429 easily downloaded from official site. Andy T.
B&Ola
- Posts 302
OK, But if I do a firmware update on my mac with the latest BM-link I get fw 1.31?
Is this firmware something else?
Stan
- Posts 593
Gatex: Can I use the Beoport in my home-office with my Windows powered PC and by plugging in my Beolab 8k ? Can it act like a "master" ?
The PC2/BeoPort can act as a master.
B&Ola
- Posts 302
B&Ola: OK, But if I do a firmware update on my mac with the latest BM-link I get fw 1.31?
/Ola
If you look at Bang & Olufsen.com they say its version 4.61!
Im totaly confused!
/Ola
Beobuddy
- Posts 1,582
Hi Andy, I think it's the softwareversion of the Beoportplayer you've mentioned. The latest firmware of the beoport is 1.31. But that it's only shown in a dialogbox on a Mac. With the pc software you can't see. Mine has 1.30 and both the pc or Mac aren't able to update the firmware. The 1.31 firmware is the one you need to use BM-link 1.5. Which has, as you probably know, more feedback to the 3000/3200/9000. If you using the beoport/pc2 only with a pc, the 1.31 isn't that much interesting. Beobuddy using half a (fake) Mac, half a pc......
Jandyt
- Posts 13,004
Cheers for that, Beobuddy. Being a bit thick, I was confused by firmware and software. I hope I haven't confused the issue even further The figure I quoted was from right-clicking on my Beoport icon then selecting 'properties' Andy T.
Keith Saunders
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
The latest version of the Beoport software is 4.61 which provides a firmware update of 1.30 (see below) Keith..
B&Ola
- Posts 302
Is it possible to set/change option with a mac/BM-link (have no IR-eye connected)
/Ola
Stan
- Posts 593
B&Ola: Is it possible to set/change option with a mac/BM-link (have no IR-eye connected)
/Ola
Yes and no. There is no screen that allows one to enter the option numerically. However, there are configurations settings that you can make that will change the option settings. In BM-Link 1.0 (what I have installed), you can set option 4 (so the IR responds to Link commands only). There might be more in a later release.
Stan
jk1002
- Boston USA
- Posts 1,620
Hmmmm ... Remembering the problems that people had in the past with upgrading their units which even involved replacing it I would probably skip buying a used beoport unless the software is reasonable close to current or you have a real good dealer relationship. Or the price is low.
Just my 2 cents ....
JK
SWISS_2
- Neuchatel, Suisse
- Posts 552
I purchased one from Lee @ Lifestyle AV last year, and it accepts all software upgrades thus far.
Page 1 of 1 (21 items)
