        1st March February 2012
	    Latest post 05-08-2007 10:05 PM by SWISS_2 . 20 replies.
								    |  05-08-2007 2:11 AM |  |
									                 kijf001Joined on 04-27-2007Posts 10 |
										    Difference beolink pc2 and beoport
										    Hi there,  is there someone who can explain what the difference is between beolink pc2 and beoport?   thanks in advance |  |
									                 djjkroonJoined on 04-18-2007Uddel, the NetherlandsPosts 113 |
										    Re: Difference beolink pc2 and beoport
										    Yep, I will try, there are none. Only the name;) Muzies,
Hans Kroon |  |
										    Thanks for the quick answering. then i will buy a secondhand beolink pc2.   cheers |  |
									                 beo4meJoined on 04-17-2007Posts 175 |
										    What about PC office and Beoport? I heard that PC Office could play with the PC switched off, something the Beoport (and possibly PC2) can not do.
 Cheers,Frank
									                 Coolskin
 Joined on 04-16-2007HollandPosts 505 |
										     djjkroon:Yep, I will try, there are none. Only the name;)
 Correction. In daily use you don't see any difference between Beolink PC2 and the Beoport. The first Beoport boxes even state Beolink PC2 on the side. But the Beoport has an improved printed circuit board. |  |
										    Thanks, that's right I have a BeoPort saying PC2.Muzies,
Hans Kroon |  |
									                 B&OlaJoined on 04-16-2007Posts 302 |
										    What is the latest firmware on PC2/Beoport?
 /Ola |  |
									                 AlexJoined on 04-23-2007Posts 223 |
										    Can I use the Beoport in my home-office with my Windows powered PC and by plugging in my Beolab 8k ? Can it act like a "master" ? |  |
									                 PhilLondonJoined on 04-16-2007LondonPosts 2,545 |
										    You can update both to the same latest firmware, and it is easy to do, so go for a pc2 without problem.  p. |  |
									                 Jandyt
 Joined on 04-01-2007Clitheroe, Lancashire, UKPosts 13,004 |
										     B&Ola:What is the latest firmware on PC2/Beoport?
 /Ola
 Hola, Ola!  It's 9.1.0.429 easily downloaded from official site. Andy T.   |  |
										    OK, But if I do a firmware update on my mac with the latest BM-link I get fw 1.31?
 Is this firmware something else?
									                 StanJoined on 04-17-2007Posts 593 |
										     Gatex:Can I use the Beoport in my home-office with my Windows powered PC and by plugging in my Beolab 8k ? Can it act like a "master" ?
 The PC2/BeoPort can act as a master. |  |
										     B&Ola:OK, But if I do a firmware update on my mac with the latest BM-link I get fw 1.31?
 /Ola
 If you look at Bang & Olufsen.com they say its version 4.61!
 Im totaly confused!
 /Ola |  |
									                 BeobuddyJoined on 04-18-2007Posts 1,582 |
										    Hi Andy,   I think it's the softwareversion of the Beoportplayer you've mentioned. The latest firmware of the beoport is 1.31.  But that it's only shown in a dialogbox on a Mac. With the pc software you can't see. Mine has 1.30 and both the pc or Mac aren't able to update the firmware.   The 1.31 firmware is the one you need to use BM-link 1.5. Which has, as you probably know, more feedback to the 3000/3200/9000. If you using the beoport/pc2 only with a pc, the 1.31 isn't that much interesting.   Beobuddy using half a (fake) Mac, half a pc...... |  |
									                 Jandyt
										    Cheers for that, Beobuddy. Being a bit thick, I was confused by firmware and software. I hope I haven't confused the issue even further  The figure I quoted was from right-clicking on my Beoport icon then selecting 'properties' Andy T. |  |
									                 Keith Saunders
 Joined on 04-16-2007Technical Advisor, Little Ann, Hampshire, UKPosts 3,810 |
										    The latest version of the Beoport software is 4.61 which provides a firmware update of 1.30 (see below)
 Keith.. |  |
										    Is it possible to set/change option with a mac/BM-link (have no IR-eye connected)
 /Ola |  |
										     B&Ola:Is it possible to set/change option with a mac/BM-link (have no IR-eye connected)
 /Ola
 Yes and no.  There is no screen that allows one to enter the option numerically.  However, there are configurations settings that you can make that will change the option settings.  In BM-Link 1.0 (what I have installed), you can set option 4 (so the IR responds to Link commands only).  There might be more in a later release.
 Stan |  |
									                 jk1002Joined on 04-16-2007Boston USAPosts 1,620 |
										    Hmmmm ... Remembering the problems that people had in the past with upgrading their units which even involved replacing it I would probably skip buying a used beoport unless the software is reasonable close to current or you have a real good dealer relationship. Or the price is low.
Just my 2 cents ....
JKBS9000, BS2300, BC2, BL2500, BL3, Bl2, BS1, BV8, BC4, A8 |  |
									                 SWISS_2Joined on 04-16-2007Neuchatel, SuissePosts 552 |
										    I purchased one from Lee @ Lifestyle AV last year, and it accepts all software upgrades thus far.   |  |
						     Page 1 of 1 (21 items)  |
