Latest post 05-08-2007 10:05 PM by SWISS_2. 20 replies.
Page 1 of 1 (21 items)
  • 05-08-2007 2:11 AM
    Difference beolink pc2 and beoport
    Hi there,
     is there someone who can explain what the difference is between beolink pc2 and beoport?
    thanks in advance
  • 05-08-2007 2:14 AM In reply to
    • djjkroon
    • Top 500 Contributor
    • Joined on 04-18-2007
    • Uddel, the Netherlands
    • Posts 113
    Re: Difference beolink pc2 and beoport
    Yep,
    I will try, there are none. Only the name;)
    Muzies, Hans Kroon
  • 05-08-2007 2:16 AM In reply to
    Thanks for the quick answering. then i will buy a secondhand beolink pc2.
    cheers
  • 05-08-2007 2:20 AM In reply to
    What about PC office and Beoport? I heard that PC Office could play with the PC switched off, something the Beoport (and possibly PC2) can not do.
    Cheers,
    Frank
  • 05-08-2007 3:29 AM In reply to
    djjkroon:
    Yep,
    Correction.
    In daily use you don't see any difference between Beolink PC2 and the Beoport.
    The first Beoport boxes even state Beolink PC2 on the side.
    But the Beoport has an improved printed circuit board.
  • 05-08-2007 5:19 AM In reply to
    • djjkroon
    • Posts 113
    Thanks, that's right I have a BeoPort saying PC2.
    Muzies, Hans Kroon
  • 05-08-2007 7:24 AM In reply to
    What is the latest firmware on PC2/Beoport?
    /Ola
  • 05-08-2007 8:37 AM In reply to
    • Alex
    • Joined on 04-23-2007
    • Posts 223
    Can I use the Beoport in my home-office with my Windows powered PC and by plugging in my Beolab 8k ? Can it act like a "master" ?
  • 05-08-2007 8:46 AM In reply to
    You can update both to the same latest firmware, and it is easy to do, so go for a pc2 without problem.
     p.
  • 05-08-2007 9:57 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    B&Ola:
    /Ola
    Hola, Ola!
    It's 9.1.0.429 easily downloaded from official site.
    Andy T.
    Poor me, never win owt!
  • 05-08-2007 10:18 AM In reply to
    OK, But if I do a firmware update on my mac with the latest BM-link I get fw 1.31?
    Is this firmware something else?
    /Ola
  • 05-08-2007 10:31 AM In reply to
    • Stan
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 593
    • Gold Member
    Gatex:
    The PC2/BeoPort can act as a master.
  • 05-08-2007 10:37 AM In reply to
    B&Ola:
    /Ola
    If you look at Bang & Olufsen.com they say its version 4.61!
    Im totaly confused!
    /Ola
  • 05-08-2007 10:42 AM In reply to
    Hi Andy,
    I think it's the softwareversion of the Beoportplayer you've mentioned.
    The latest firmware of the beoport is 1.31.
    But that it's only shown in a dialogbox on a Mac. With the pc software you can't see.
    Mine has 1.30 and both the pc or Mac aren't able to update the firmware.
    The 1.31 firmware is the one you need to use BM-link 1.5. Which has, as you probably know, more feedback to the 3000/3200/9000.
    If you using the beoport/pc2 only with a pc, the 1.31 isn't that much interesting.
    Beobuddy
    using half a (fake) Mac, half a pc......
  • 05-08-2007 3:19 PM In reply to
    • Jandyt
    • Posts 13,004
    Cheers for that, Beobuddy. Being a bit thick, I was confused by firmware and software. I hope I haven't confused the issue even further Embarrassed
    The figure I quoted was from right-clicking on my Beoport icon then selecting 'properties'
    Andy T.
  • 05-08-2007 3:38 PM In reply to
    The latest version of the Beoport software is 4.61 which provides a firmware update of 1.30 (see below)
    Revision
    Keith..
    Regards Keith....
  • 05-08-2007 5:00 PM In reply to
    Is it possible to set/change option with a mac/BM-link (have no IR-eye connected)
    /Ola
  • 05-08-2007 9:38 PM In reply to
    • Stan
    • Posts 593
    • Gold Member
    B&Ola:
    /Ola
    Yes and no.  There is no screen that allows one to enter the option numerically.  However, there are configurations settings that you can make that will change the option settings.  In BM-Link 1.0 (what I have installed), you can set option 4 (so the IR responds to Link commands only).  There might be more in a later release.
    Stan
  • 05-08-2007 9:51 PM In reply to
    Hmmmm ... Remembering the problems that people had in the past with upgrading their units which even involved replacing it I would probably skip buying a used beoport unless the software is reasonable close to current or you have a real good dealer relationship. Or the price is low. Just my 2 cents .... JK
  • 05-08-2007 10:05 PM In reply to
    • SWISS_2
    • Joined on 04-16-2007
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    I purchased one from Lee @ Lifestyle AV last year, and it accepts all software upgrades thus far.
