1st March February 2012
03-13-2008
File size: 0 B
This afternoon i had a few spare hours, so really cracked on and got
the rest of the wall paper stripped and picture rail removed and also
knocked off some loose plaster. As you can see the BV3 is still in the
room, and i know i should get it out of the room but as ive said before
i am still using the front room while the work goes on and with two
kids CBeebies is a must. Dont worry its perfectly safe.
