I'm clogging up the forum with questions it seems. Last one on this Beogram I hope.
My Beogram 5005 is down in sound drastically on the left channel. From other searches it has been suggested that perhaps the muting switch is at fault, given that when the arm is initially lifting from the record surface, the left channel momentarily goes to normal volume, then cuts again.
While the needle is on the playing surface, the left side is " tinny " and weak - effectively inaudible.
I have had the muting switch apart, nothing wrong as far as I can tell. Could another cause be the left channel not working on the cartridge itself ? If so how do I test for that.
Or any other possible causes.
I'm happy to send the MMC4 cartridge to anyone in Australia if they would like to check that it plays correctly on their turntable. Willing to send further afield, but return postage could only be paid in aussie $ or via Paypal.
As yet I haven't been able to play any records, it's proving to be a right pain, but I'll get to the bottom of it eventually.
Thanks, I look forward to replies.
