Hi, I'm a first time poster. I have just acquired a Beogram 1500 and Beocenter 2000 for free.
The BG1500 is missing a needle so I'm also looking for a new stylus. Did you say some were interchangeable?
Other than the stylus I have an issue with the crome speed selector but the motor seem fine, although currently only running at 45.
The BC2000 record player works fine but the cassette deck doesn't. Not sure I'll bother fixing that though to be honest. Oh, for some reason I can't connect speakers to it either so I'm using the headphone socket, a splitter and an external amplifier which actually works well as a workaround :)
