Latest post 05-16-2007 11:42 AM by Keith Saunders. 13 replies.
Page 1 of 1 (14 items)
  • 04-22-2007 4:37 AM
    • Beowulf
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Derbyshire
    • Posts 143
    Converting German Beocom 1401 to UK plug colour codes
    Is anyone able to tell me which colour wires on a German Beocom 1401 correspond to a UK phone plug colour codes?
    Regards
    Dave
    Beowulf
  • 04-24-2007 4:56 AM In reply to
    Re: Converting German Beocom 1401 to UK plug colour codes
    As a matter of interest, if and when you do find out just what connectors are used/changed... if you let me know then I will add it to BeoTech.
    Steve
  • 04-24-2007 8:03 AM In reply to
    • Beowulf
    • Derbyshire
    • Posts 143
    Hi Steve, I think Nobby (Neil) may have the answer, but haven't seen him on the forum, I will send th einfo on if I get it.
    Kind regards
    Dave
    Beowulf
  • 04-24-2007 2:50 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Beowulf:
    Kind regards
    Dave
    Niel is around, He registered a few days ago. May be worth dropping him a PM.
    CraigBig Smile
  • 04-24-2007 10:31 PM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Look up German (TAE) to UK (BS 631) adapter, see what you come up with.
  • 04-25-2007 2:23 AM In reply to
    I guess you are looking for an adapter such as the one below or are you looking for a German to UK adapter ?
    Adapter for Germany
    Regards Keith....
  • 04-25-2007 2:39 AM In reply to
    • Beowulf
    • Derbyshire
    • Posts 143
    Hi Keith, There is no plug fitted to the phone, but the wire colour codes are German, Thanks for the trouble you went to!
    Cheers
    Dave
    Beowulf
  • 04-25-2007 3:20 AM In reply to
    Beowulf:
    Cheers
    Dave
    Dave,
    Can you confirm the codes of the colours of the wires coming from your German phone. I know someone who has a german B&O phone he is using in the UK, so I can ask him what the connections are.
    Keith..
    Regards Keith....
  • 04-25-2007 4:58 PM In reply to
    • Beowulf
    • Derbyshire
    • Posts 143
    Hi Keith
    Red, Yellow, Blue, Dark Brown almost Black.
    Thanks again Keith
    Beowulf
  • 05-06-2007 4:06 AM In reply to
    • Beowulf
    • Derbyshire
    • Posts 143
    Hi Keith,
    Not sure if you managed to view my last post above regarding the colour coding?
    Regards
    Dave
    Beowulf
  • 05-08-2007 3:52 AM In reply to
    Dave,
    Sorry for the delay in getting back to you, but I have been away in Italy and justed returned.
    I have not yet had the opportunity to view the wiring of wires, but I am visiting my friend later this week when I will be able to check teh connections.
    Keith..
    Regards Keith....
  • 05-16-2007 7:55 AM In reply to
    • Beowulf
    • Derbyshire
    • Posts 143
    Hi Keith,
    Thanks for your reply, and the efforts you have made.
    Kind regards
    Dave
    Beowulf
  • 05-16-2007 11:31 AM In reply to
    Hello Dave,
    Sorry for the delay, but frankly I had forgotten, but here is the data now.
    The UK phone plug as shown below is numbered from pin 1 to pin 6 left to right.
    Pins 1 & 6 are not wired and pin 4 is wired but not used. The voice pair is on pins 2 & 5 and pin 3 is for ring
    UK Phone Plug
    Pin 1 is NOT USED
    Pin 2 is BLUE
    Pin 3 is WHITE
    Pin 4 is RED
    Pin 5 is GREEN
    Pin 6 is NOT USED
    I hope this answers your wiring problem. If at any time you need a new lead, the B&O part number is 1004926
    Keith..
    Regards Keith....
  • 05-16-2007 11:42 AM In reply to
    Sorry Dave,
    I missed a further piece of data, you have noted that your coloured wires are not 100% the same as the ones I have quoted because apparently at some point the colour coding was changed. To ensure we have the correct translation of coloured wires by version you will have to slide the small cover at the bottom of the handset downwards and behind it are two small switches, to the right and behind this switch plate is a very small plug. Please state the ORDER of your colours in this plug from bottom to top (top being by the wire outlet)
    Keith..
    Regards Keith....
