1st March February 2012
04-22-2007 4:37 AM
Beowulf
- Joined on 04-16-2007
- Derbyshire
- Posts 143
Converting German Beocom 1401 to UK plug colour codes
Is anyone able to tell me which colour wires on a German Beocom 1401 correspond to a UK phone plug colour codes?
Regards
Dave
Re: Converting German Beocom 1401 to UK plug colour codes
As a matter of interest, if and when you do find out just what connectors are used/changed... if you let me know then I will add it to BeoTech. Steve
Beowulf
- Derbyshire
- Posts 143
Hi Steve, I think Nobby (Neil) may have the answer, but haven't seen him on the forum, I will send th einfo on if I get it. Kind regards Dave
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Beowulf: Hi Steve, I think Nobby (Neil) may have the answer, but haven't seen him on the forum, I will send th einfo on if I get it. Kind regards Dave
Niel is around, He registered a few days ago. May be worth dropping him a PM. Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Dave
- Joined on 04-17-2007
- Brisbane, Australia
- Posts 2,328
Look up German (TAE) to UK (BS 631) adapter, see what you come up with.
Keith Saunders
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
I guess you are looking for an adapter such as the one below or are you looking for a German to UK adapter ?
Beowulf
- Derbyshire
- Posts 143
Hi Keith, There is no plug fitted to the phone, but the wire colour codes are German, Thanks for the trouble you went to! Cheers Dave
Keith Saunders
- Posts 3,810
Beowulf: Hi Keith, There is no plug fitted to the phone, but the wire colour codes are German, Thanks for the trouble you went to! Cheers Dave
Dave, Can you confirm the codes of the colours of the wires coming from your German phone. I know someone who has a german B&O phone he is using in the UK, so I can ask him what the connections are. Keith..
Beowulf
- Derbyshire
- Posts 143
Hi Keith Red, Yellow, Blue, Dark Brown almost Black. Thanks again Keith
Beowulf
- Derbyshire
- Posts 143
Hi Keith, Not sure if you managed to view my last post above regarding the colour coding? Regards Dave
Keith Saunders
- Posts 3,810
Dave, Sorry for the delay in getting back to you, but I have been away in Italy and justed returned. I have not yet had the opportunity to view the wiring of wires, but I am visiting my friend later this week when I will be able to check teh connections. Keith..
Beowulf
- Derbyshire
- Posts 143
Hi Keith, Thanks for your reply, and the efforts you have made. Kind regards Dave
Keith Saunders
- Posts 3,810
Hello Dave, Sorry for the delay, but frankly I had forgotten, but here is the data now. The UK phone plug as shown below is numbered from pin 1 to pin 6 left to right. Pins 1 & 6 are not wired and pin 4 is wired but not used. The voice pair is on pins 2 & 5 and pin 3 is for ring
Pin 1 is NOT USED Pin 2 is BLUE Pin 3 is WHITE Pin 4 is RED Pin 5 is GREEN Pin 6 is NOT USED I hope this answers your wiring problem. If at any time you need a new lead, the B&O part number is 1004926 Keith..
Keith Saunders
- Posts 3,810
Sorry Dave, I missed a further piece of data, you have noted that your coloured wires are not 100% the same as the ones I have quoted because apparently at some point the colour coding was changed. To ensure we have the correct translation of coloured wires by version you will have to slide the small cover at the bottom of the handset downwards and behind it are two small switches, to the right and behind this switch plate is a very small plug. Please state the ORDER of your colours in this plug from bottom to top (top being by the wire outlet) Keith..
Page 1 of 1 (14 items)
