Latest post 11-23-2007 11:37 AM by MartinW. 3 replies.
Page 1 of 1 (4 items)
  • 11-07-2007 4:06 AM
    • Redoctover
    • Not Ranked
    • Joined on 06-08-2007
    • Singapore and Korea
    • Posts 2
    Problem Beo5 connect with pc
    HI~ all
    Could you inform me connect with pc?
    When I connect with pc, my pc doesn't rocognize it.
     My dealer said "Pls use PCI-USB card. Because My Main board controller SIS7001.
     So I bought NEC PCI-USB card and use it. But result is same.
     Pls Help me...
    Redoctover My B&O BL2,BL8000,BL6000,BL4000,BS9000,BL2000,BST3
  • 11-15-2007 5:07 AM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Re: Problem Beo5 connect with pc
    Please, sorry for my english, it's not my language.
    I'll try to help you, i got the same problem. Try this:
    - Turn off your Beo5 pressing and holding the central button.
    - Place the Beo5 in its support, it will be connected in a second.
    -After this, the pc will recognize it. If not, i think you know how to install drivers for a new hardware. Drivers are in a folder after programm is installed. There is a file called driverinstaller.exe, i clicked it, but i don't know if it is needed, because i made a lot of tests.
    I hope it will help you.
     Regards
    Quim
  • 11-15-2007 5:28 AM In reply to
    I would uninstall the software completely and then re-install.
  • 11-23-2007 11:37 AM In reply to
    B&O have released a software patch today for the Beo5 config tool - one area the patch focuses on is the connections issues with PCs.
    It also improves handling logos and adds some new DVD controllers and STBs.
    BV7-40MK4BR,7-32,6-22,6-23,6-26,BSnd5,9000,BLab9,3,4000,2,BCom2,6000,Btalk1200,LC2s,Lutron
