the above answer is correct, however, i'm continually surprised that the questions that are asked here can often be very easily answered by your dealer.
I'm not saying don't ask here, however if you are keen on buying anything then the dealers should be happy to answer your questions and the more questions you ask your dealer the better relationship you build with them and the better service you will get.
jazz
