Latest post 10-15-2007 6:40 AM by Sebastien. 9 replies.
Page 1 of 1 (10 items)
  • 10-14-2007 4:26 AM
    Beovision 9 - Speakers
    Is the Beovision 9 equipped with built-in speakers?
    S.F
  • 10-14-2007 4:29 AM In reply to
    • YannChris
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Larmor-Plage, France
    • Posts 276
    Re: Beovision 9 - Speakers
    A mono central speaker with ALT is buit in the BV9.
    It might be based on BL 7.4.
    So you will need other front speakers to get a stereo sound, and at least 2 rear-speakers to get surround sound.
    Yann.
    Ne pas s'en faire et boire frais!
    Mon install en images: cliquez sur mon profil, au dessus de mon avatar - Puis "My files" tout en bas.
    Pictures of my setup: click on my nickname, above my avatar. Then "my files" at the bottom of the page.
  • 10-14-2007 7:43 AM In reply to
    the above answer is correct, however, i'm continually surprised that the questions that are asked here can often be very easily answered by your dealer.
    I'm not saying don't ask here, however if you are keen on buying anything then the dealers should be happy to answer your questions and the more questions you ask your dealer the better relationship you build with them and the better service you will get.
    jazz
  • 10-14-2007 11:13 AM In reply to
    Sometimes going to a dealer with a bit of knowledge can make the whole process less intimidating. It is a problem with B1 dealers - entering into the shop sends an immediate message that you wishing to buy some B&O. The old store in store shops had the advantage that one could surreptitiously  admire the B&O!  I know that is how I started!  One often does not want to appear ignorant either  so this type of forum can allow you to ask questions that you may think are too simple to ask a dealer.  As Lee has said elsewhere on site, nothing is a silly question!
  • 10-14-2007 1:03 PM In reply to
    Thanks Jazz for your kind advise. However, it's the weekend (Sunday) so dealers are off I guess. At least I have something in hand when I visit them in the coming week. Some users report that their dealers are located at 300 Km from their place. In my case, I have to drive 125 Km to reach the showroom. For this reason, I use the phone in most of the time to inquire about the products, but using the telephone doesn't solve my problems. That's why I am using this forum to know more about the B&O products knowing that I am not a beginner with B&O as I do have a Beovision 4-50 + Beocenter 2 + 4 x Beolab 3 + Beolab 2 + Beolab 7-2+ Beolab 3500 (connected through master link).
    S.F
  • 10-14-2007 3:18 PM In reply to
    • Alex
    • Top 25 Contributor
    • Bath & Cardiff, UK
    • Posts 2,990
    Four BeoLab 2s?
     Weekly top artists:
  • 10-14-2007 3:40 PM In reply to
    Alex:
    Four BeoLab 2s?
    Hmmm. think maybe he means 4 BL3's and one Bl2....
    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
  • 10-14-2007 4:43 PM In reply to
    • Alex
    • Posts 2,990
    Of course, mybad.
     Weekly top artists:
  • 10-14-2007 4:47 PM In reply to
    • Tom
    • Luxembourg
    • Posts 3,175
    would be a great setup, with BL2 on the walls all around the room...
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 10-15-2007 6:40 AM In reply to
    4 x Beolab 3 on the walls + Beolab 2 on the floor.
    S.F
