Latest post 12-26-2007 12:16 PM by Doc. 17 replies.
Page 1 of 1 (18 items)
  • 09-29-2007 6:09 PM In reply to
    • misled
    • Not Ranked
    • Joined on 04-25-2007
    • Switzerland
    • Posts 66
    Re: Beo-5 and the LC-2
    with the sw you can added more lc-2!
    bring at your dealer for a new configuration.
    BVision10-46,BLab11,BSound5,BMaster5,BLab8000,BLab6000,BLab2500,BCom5,BCom6000,BeoTime,BeoPort,Beo4,Beo5
  • 09-29-2007 6:32 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    There seem to be mixed signals from my Beo5, Ed.
    I have one LC2 called lamp2 and two LC1s called lamp1 and lamp9.
    I can raise and lower Lamp2 without affecting the others, but if I switch Lamp 2 off, they all go off
    I cannot raise or lower the LC1s at all, though I can with Beo4.
    When I press Lamp1, it comes on even though I didn't press 'On'
    When Lamp1 is on, I can switch it off and on again but if I try to raise it, it raises Lamp 2 instead, then if I press off and on again, all the lamps come on though it still says Lamp 1 on the display.
    Very, very confusing.
    Andy T.
    Poor me, never win owt!
  • 09-30-2007 7:28 AM In reply to
    • Jandyt
    • Posts 13,004
    No Ed, I don't think there is a fault.
    Next time you go to your dealer, you could ask him to add some buttons.
    At the moment, when you press Lamp2, you only have the option of 'On' or 'Off' and you have been using the hard button to go up and down.
    In the Lamp2 screen you could add two buttons called UP and DOWN
    On the UP button ask him to add the IR command........
    Light,goto, 2, Step_up.......and on the down button......Light goto, 2, Step_down
    As you have 8 LC2s you will have to do the same for all the lamp screens, substituting 5 for 2 etc.
    A much easier way would be to set Light pictures for different situations for example Reading, watching DVD, listening to music etc
    There is already the option of 9 light pictures which should be plenty for one room.
    Andy T.
  • 09-30-2007 8:18 AM In reply to
    jandyt:
    Andy T.
    Ahh great Andy I will test this, thanx mate
  • 09-30-2007 8:31 AM In reply to
    • Jandyt
    • Posts 13,004
    Good.
    This is a long learning proccess and we will keep on improving.
    Andy T.
  • 09-30-2007 2:06 PM In reply to
    Andy I have tested this but you must press many times to lightup/down, it would be better if you just press and hold to light Up/down ??
  • 09-30-2007 2:13 PM In reply to
    solved, just need to check the "continiues" box
  • 09-30-2007 2:18 PM In reply to
    • Jandyt
    • Posts 13,004
    Yes Anders. There is a tab called IR Long but the only thing in it is Stand-by.
    I am working on that one.
    Andy T.
  • 09-30-2007 2:22 PM In reply to
    • Jandyt
    • Posts 13,004
    Laughing
    I never even noticed the continues box!
    Well done. Yes -  thumbs up Does it work?
    Andy T.
  • 09-30-2007 2:34 PM In reply to
  • 09-30-2007 3:36 PM In reply to
    jandyt:
    Laughing
    Andy T.
    A little box in the "IR" section of the "edit property" tab in the Beo5 Configuration Tool Software...isn't it?
    Some white coat gentlemen are waiting for you both just out there !!  Laughing
    Santiago
  • 10-02-2007 3:52 PM In reply to
    • Jandyt
    • Posts 13,004
    Thanks Anders for pointing out the continuous box.
    All my lights are sorted now.Big Smile
    Poor, overworked dealers!
  • 12-26-2007 11:25 AM In reply to
    • Doc
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 585
    Can somebody put together a little manual for using/controlling LC2 by Beo5? Maybe something for Keith?
    Biggest question: how to adress a number to each lamp.....
  • 12-26-2007 12:16 PM In reply to
    • Doc
    • Posts 585
    Eduard,
    Thanks for the reply: you have an email.....
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
