Latest post 09-03-2007 4:28 AM by Keith Saunders. 1 replies.
Page 1 of 1 (2 items)
  • 09-02-2007 6:06 PM
    Beocom 2 handset registered to 2 PSTN base
    Is this possible ? I believe from other posts that it is possble to up to 4 bases
    If I open both bases (both the older style) I can see that they are both available but I can only register the phone to one of them. Am I missing something ?
    Cheers Kev
    Marching On Together
  • 09-03-2007 4:28 AM In reply to
    Re: Beocom 2 handset registered to 2 PSTN base
    It is possible, but not if you have quite old bases.
    If you have a handset registered to several bases, you can choose which base to use via the SELECT BASE menu
    Instead of choosing a specific base, you can choose AUTO SELECT. The handset will then search for another base if the transmission signal to its present base is lost. Clearly if an on-going call is in progress when it changes to a different base, then the call is dropped.
    The available bases are distinguished by their serial numbers, which you will normally find on the bottom of the base.
    One point often not fully understood when using more than one base is the common phonebook is only valid when a given handset uses its BASE NUMBER 1 i.e the base to which the handset was registered as handset number 1.
    I have only used this facility myself on Beocom 6000's but the the principle is the same.
    Regards Keith....
