Graham,
Followed your directions - only thing that changed is now both speaker displys are lit - still no output.
Then, I reversed the Chain and connected the other speaker first...
Finally, I've even connected the 2 speakers direct (one cable to one 9300 output).
These are BRAND NEW B&O cables, purchased from dealer (#6270698)
I'm sure that I just don't have the "launch code" figured out!
Is there any output control - in other words, which speaker output is enabled from the 9300 - or is that function automatic?
I guess that:
A) There could be a problem with the Pentas connection hardware (jacks)
B) There could be a faulty cable - I guess I can test every conductor of each cable - but with all the ways I've tried to connect, both cables would have to be bad.
