I just aquired a 5500 system with Penta 1 Speakers, and I'm wondering what is the best way to connect the speakers to the receiver. The three options are 1.) using the 4 pin Link cable (speakers display info), 2.) a pair of clip style terminals for bare wire 3.) line level RCA inputs. From my experience taking an amplified signal, as in the first two options, and amplifying it again at the speaker, is not the best method. The third option would bypass the amplification in the receiver and let the speakers do all the work, which sounds like the cleanest delivery to me. Also, it is not neccesary to me that the speakers display the source and volume on their LED display, infact it's a bit distracting. Lastly on this subject, with option #3 I can use some REALLY nice interconnects to connect the receiver (actually preamp in this case) with the speakers. I'm certain that my interconnects will sound far better then the stock Link speaker wire that came with them.
One other question I have is, how the heck do you remove the grills on the Penta speakers? I read here that the midrange drivers have foam surrounds, and I need to inspect them. The system was described as a 7 out of 10, but upon unpacking I found things were closer to a 5 or 6 out of 10. Everything sounds great so far, but I need to be certain everything is in working order.
Curtis
