Latest post 08-02-2007 2:34 AM by Keith Saunders. 3 replies.
Page 1 of 1 (4 items)
  • 08-02-2007 1:06 AM
    FM antennas...
    Are the connections for the newer B&O equipment the same for the antenna..?? BS9000 and BC9500??
  • 08-02-2007 2:05 AM In reply to
    Re: FM antennas...
    Normally 75 ohm aerial plugs are used for FM, but if you have a DAB radio then it will be an "F" plug.
    For example the Beocentre 6 with FM & DAB has the normal 75 ohm socket for FM and an "F" socket for DAB
    Regards Keith....
  • 08-02-2007 2:22 AM In reply to
    Re: FM antennas...
    Thanks Keith...
     So these are not BnO specifically???
    K
  • 08-02-2007 2:34 AM In reply to
    Re: FM antennas...
    You  are correct, these are standard to almost all audio and video products made by most company's. There are some exceptions
    Regards Keith....
