Normally 75 ohm aerial plugs are used for FM, but if you have a DAB radio then it will be an "F" plug.
For example the Beocentre 6 with FM & DAB has the normal 75 ohm socket for FM and an "F" socket for DAB
Regards Keith....
Thanks Keith...
So these are not BnO specifically???
K
