I have just looked in to the AV7000 it will not work as a master on the link system. more like a link product.
so if you set your BS9000 in option 5 or 6, you can play from the BC9500 all the way around. note that your ML link rooms only can play from the BC9500 from now on...
Maybe the BC can go in to option 5, you can test it whit the remote to see if it's possible...
