Latest post 07-22-2007 10:35 PM by Dave. 1 replies.
Page 1 of 1 (2 items)
  • 07-22-2007 2:49 PM
    Beolab 9 Bass settings
    Any reccomendations on bass settings given the following placement?
    Right beolab 9 is in a corner with the setting set at corner.
    Left speaker is same distance from rear wall as right speaker and same distance from corner,  but the corner it is near is a 45 degree corner. On the 45 degree wall adjacent to the speaker is a fireplace with a small amount of tile around it and glass over the firebox. I know ultimatley it is a matter of taste and what sounds good to us but would welcome any opinions.
    Thanks!
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 07-22-2007 10:35 PM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Re: Beolab 9 Bass settings
    Try the different settings and placements out and listen until you're happy (maybe even do whet the listening panal does, and go to a live performance during this time of figuring out how you want the sound to be) , i'd firstly try both on corner, your living room sounds exactly like mine!
