Any reccomendations on bass settings given the following placement?
Right beolab 9 is in a corner with the setting set at corner.
Left speaker is same distance from rear wall as right speaker and same distance from corner, but the corner it is near is a 45 degree corner. On the 45 degree wall adjacent to the speaker is a fireplace with a small amount of tile around it and glass over the firebox. I know ultimatley it is a matter of taste and what sounds good to us but would welcome any opinions.
Thanks!
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
