Latest post 07-19-2007 4:34 AM by archie. 5 replies.
Page 1 of 1 (6 items)
  • 07-17-2007 10:51 AM
    • archie
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Paris
    • Posts 497
    HC amplifier pre-out to BL8000
    Hello.
    do  you have diagram to make a cable between pre-out HC  amplifier and lab8000 ?
     which signal to apply to pin 4 to make "on" the beolab ?
     thank you
    DU BEAU, DU BON, DU BO.
  • 07-17-2007 1:07 PM In reply to
    • Gerd
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    Re: HC amplifier pre-out to BL8000
    You need a supply of approx 5V on Powerlink Pin 4 to switch the BeoLab on. But why don't you just connect it to the "line" (RCA) input?
  • 07-17-2007 1:22 PM In reply to
    • archie
    • Paris
    • Posts 497
    "..But why don't you just connect it to the "line" (RCA) input?.."
    because i don't want switch on/off each time.
  • 07-17-2007 3:09 PM In reply to
    They will switch off automatically 3 minutues after signal stops and on again when signal starts!
    Regards Graham
  • 07-17-2007 4:38 PM In reply to
    • archie
    • Paris
    • Posts 497
    Yes, but the BL8000 are connected to the BS9000 too.
    In fact  i want conected the BL 8000 in same time to BO hifi pre amplifier and denon HC  preamplifier.
  • 07-19-2007 4:34 AM In reply to
    • archie
    • Paris
    • Posts 497
    A friend who know electronic try to make a sytem with the AC outlet of the amplifier via a 220v -> 5v transfo.
    with this system when you put "on" the amplifier, the lab go "on" too.
    to follow........
