DU BEAU, DU BON, DU BO.
"..But why don't you just connect it to the "line" (RCA) input?.."
because i don't want switch on/off each time.
They will switch off automatically 3 minutues after signal stops and on again when signal starts!
Regards Graham
Yes, but the BL8000 are connected to the BS9000 too.
In fact i want conected the BL 8000 in same time to BO hifi pre amplifier and denon HC preamplifier.
A friend who know electronic try to make a sytem with the AC outlet of the amplifier via a 220v -> 5v transfo.
with this system when you put "on" the amplifier, the lab go "on" too.
to follow........
