Latest post 02-29-2012 2:19 PM by jfa. 2 replies.
Page 1 of 1 (3 items)
  • 02-26-2012 7:20 PM
    • jfa
    • Not Ranked
    • Joined on 02-20-2012
    • Posts 2
    • Silver Member
    beolab 8000 repair
    My beolab loudspeaker has a relay problem - the relay energizes but the relay contacts don't tranfer the line voltage to TR1.
    where can I locate and purchase this relay - item # RL1 - # 7600106 - 24V coil
  • 02-28-2012 12:32 PM In reply to
    Re: beolab 8000 repair
    I think I may have the same problem... If you do find out, please drop a line on the forum... Thanks!
    September 2009 1st prize winner....
    Filed under:
  • 02-29-2012 2:19 PM In reply to
    • jfa
    • Not Ranked
    • Posts 2
    • Silver Member
    I found them at Newark Electronic USA
    Make Panasonic EW ALA2F24
    Filed under:
