My beolab loudspeaker has a relay problem - the relay energizes but the relay contacts don't tranfer the line voltage to TR1.
where can I locate and purchase this relay - item # RL1 - # 7600106 - 24V coil
I think I may have the same problem... If you do find out, please drop a line on the forum... Thanks!
September 2009 1st prize winner....
I found them at Newark Electronic USA
Make Panasonic EW ALA2F24
