Latest post 02-10-2012 1:23 PM by bobtovar. 8 replies.
Page 1 of 1 (9 items)
  • 02-08-2012 1:26 PM
    Does anyone know how to put door cable on a beosystem 2500
    i have this beosystem 2500 that works great but the door cables are off. And i cant find a f m antenna that will fit. can i put the cables back on myself or will i have to take it to a repair shop. I think i pretty handy.
    Filed under:
  • 02-08-2012 1:32 PM In reply to
    • Toby
    • Not Ranked
    • Joined on 12-04-2010
    • Worthing
    • Posts 23
    • Gold Member
    Re: Does anyone know how to put door cable on a beosystem 2500
    I have the same problem with a BS3000, after having a look it looks like a very fiddly job, so I decided to send it off to a service centre to be fixed.
  • 02-08-2012 4:16 PM In reply to
    I managed to do it twice, but it takes a lot and I mean a lot of patience to do the job!
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 02-08-2012 4:49 PM In reply to
    Is this something I wil need a breakdown to do?
  • 02-08-2012 4:53 PM In reply to
    Sorry but what do you mean by "breakdown". Don't know that word and Google translates this word as "failure" in Dutch?
  • 02-08-2012 5:32 PM In reply to
    sorry im in Texas.i guess what i ment is do i need a schematic or manual ? and how long did it take you to put the cables on.
  • 02-08-2012 6:01 PM In reply to
    Yes, if you upgrade your membership to Silver you have access to service manuals!
    Took the whole cord out and started from zero. About half a day?Super Angry
    But the satisfaction you get afterwards. Yes -  thumbs up
    Here's a peek from my own manual:
  • 02-08-2012 6:07 PM In reply to
    bobtovar:
    You can find them regularly on Ebay, and I have them tooSmile
  • 02-10-2012 1:23 PM In reply to
    thanks for leslie for your help.I am going to try to do this this weekend.   can you tell me what the connector is called that goes in the antenna receptacle. mabe i can find a andapter locally.
