Hi!
I'm very confused.
BeoSound 3200 was switched off for 2-3 months because of the repair of my rooms and now it doesn't work partially:
1) It doesn't react for no one keys of its front panel except the "LOAD" button. Therefore I can only load CDs.
2) It doesn't react for no one keys of my Beo 4 or Beo 1000.
3) It works in slave mode (connecting with BeoVision 9000) but only 1-2 mins, then it turns off automatically.
I have already tried all options (0, 1, 2). BS3200 indicates that the option value is changing but it boots not.
It looks like some PIN-code issue because previously its red LED had blinked after the power disconnection for more than 10 mins and then it asked PIN-code after turning on. Its red LED only illuminates now :((
How can I enter my PIN-code or reset it? I have some repair experience! Or I only must take it over to service centre?
Please help!
Thanks in advance!
