Latest post 02-10-2012 4:04 PM by Blackrix. 8 replies.
Page 1 of 1 (9 items)
  • 02-07-2012 8:44 PM
    • JIeo
    • Not Ranked
    • Joined on 12-13-2007
    • Russia
    • Posts 39
    PIN-code issue after switching off my BeoSound 3200 for a few months
    Hi!
    I'm very confused.
    BeoSound 3200 was switched off for 2-3 months because of the repair of my rooms and now it doesn't work partially:
    1) It doesn't react for no one keys of its front panel except the "LOAD" button. Therefore I can only load CDs.
    2) It doesn't react for no one keys of my Beo 4 or Beo 1000.
    3) It works in slave mode (connecting with BeoVision 9000) but only 1-2 mins, then it turns off automatically.
    I have already tried all options (0, 1, 2). BS3200 indicates that the option value is changing but it boots not.
    It looks like some PIN-code issue because previously its red LED had blinked after the power disconnection for more than 10 mins and then it asked PIN-code after turning on. Its red LED only illuminates now :((
    How can I enter my PIN-code or reset it? I have some repair experience! Or I only must take it over to service centre?
    Please help!
    Thanks in advance!
  • 02-08-2012 7:47 AM In reply to
    Re: PIN-code issue after switching off my BeoSound 3200 for a few months
    You need the original PIN to unlock it or you have to request the 5-digit Mastercode for your BeoSound at your dealer.
  • 02-09-2012 8:05 AM In reply to
    • JIeo
    • Not Ranked
    • Russia
    • Posts 39
    I know the original PIN-code, but how can I type it if BS3200 doesn't suggest to type it at all?
  • 02-09-2012 1:24 PM In reply to
    Change the BS3200 to Option 1 and select a source using the keyboard on your BeoSound. Now you should be able to enter the PIN code.
  • 02-10-2012 8:24 AM In reply to
    • JIeo
    • Not Ranked
    • Russia
    • Posts 39
    1. "Change the BS3200 to Option 1" - done.
    2. "Select a source (for example RADIO?) using the keyboard on your BeoSound" - impossible because BS3200 doesn't react.
  • 02-10-2012 11:48 AM In reply to
    In that case something is probably wrong with your BeoSound. What happens if you switch it on now by remote?
  • 02-10-2012 11:56 AM In reply to
    • JIeo
    • Not Ranked
    • Russia
    • Posts 39
    I have already written in the first message:
    "It doesn't react for no one keys of my Beo 4 or Beo 1000".
  • 02-10-2012 12:57 PM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    Have a look at THIS THREAD where someone else had the same problem but on a BS9000. Looks like it needs to go to to the service agent.
    If you think nobody cares, try missing a couple of payments.
  • 02-10-2012 4:04 PM In reply to
    JIeo:
    Sorry, missed that one. I agree that it might need service for this problem.......
