Latest post 01-25-2012 12:12 PM by stotty1111. 0 replies.
Page 1 of 1 (1 items)
  • 01-25-2012 12:12 PM
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    BV 6-26
    Now got hold of a new boxed piece of the above, it is for use in france, it has a digi card fitted - to change receive standard, use menu 0,0 go to get inroservice area to change receive std to L(secam) will the digi bit decode TNT French Freeview or what else do I need to do.
    Tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
