Now got hold of a new boxed piece of the above, it is for use in france, it has a digi card fitted - to change receive standard, use menu 0,0 go to get inroservice area to change receive std to L(secam) will the digi bit decode TNT French Freeview or what else do I need to do.
Tony
I always try to operate using/following the KISS principle -- Keep it simple stupid!
