Hi
I am using a Beolink 5000 with a Beosystem 2300. On the 2300 there are two Radio tuner banks, A and B. There is a button on the 2300 to switch between them. Is there any way to switch between Radio A and B from the Beolink 5000?
Thanks and Regards
Rudi
At a guess I'd say it can't be done - according to the manual the 2300 is 'designed for close up operation'! But have you tired 'SHIFT' then 'SOUND' - this does the 'TURN' function for cassettes on my BC9500. Otherwise try 'SHIFT' followed by other (non-source) keys.
Guy
I just checked the BL5000 manual - have you tried 'GOTO' then 'TURN' - this is supposed to change radio bands?
Hi Guy1680
Goto - Turn does indeed change the radio band (from FM to AM and back). What I would like to do is different though. The 2300 has a RA/RB key which switches between two station storage banks 'A' and 'B'. So far I have not found any shift combination on the Beolink 5000 that duplicates the funtion of the RA/RB key on the 2300.
I understand but thought that the GOTO TURN may toggle between bands and RA/RB.
My son has a BC2300 operated with a Beo4 so I'll ask him tonight if he knows of a way of changing it.
