Latest post 01-12-2012 7:32 AM by Guy1680. 4 replies.
Page 1 of 1 (5 items)
  • 01-11-2012 5:39 PM
    Beolink 5000 - Beosystem 2300 - Radio A and B
    Hi
    I am using a Beolink 5000 with a Beosystem 2300. On the 2300 there are two Radio tuner banks, A and B. There is a button on the 2300 to switch between them. Is there any way to switch between Radio A and B from the Beolink 5000?
    Thanks and Regards
    Rudi
  • 01-12-2012 5:17 AM In reply to
    • Guy1680
    • Top 500 Contributor
    • Joined on 08-18-2007
    • Viborg, Denmark
    • Posts 104
    • Gold Member
    Re: Beolink 5000 - Beosystem 2300 - Radio A and B
    At a guess I'd say it can't be done - according to the manual the 2300 is 'designed for close up operation'!  But have you tired 'SHIFT' then 'SOUND' - this does the 'TURN' function for cassettes on my BC9500.  Otherwise try 'SHIFT' followed by other (non-source) keys.
    Guy
  • 01-12-2012 5:21 AM In reply to
    • Guy1680
    • Viborg, Denmark
    • Posts 104
    • Gold Member
    I just checked the BL5000 manual - have you tried 'GOTO' then 'TURN' - this is supposed to change radio bands?
  • 01-12-2012 7:29 AM In reply to
    Hi Guy1680
    Goto - Turn does indeed change the radio band (from FM to AM and back). What I would like to do is different though. The 2300 has a RA/RB key which switches between two station storage banks 'A' and 'B'. So far I have not found any shift combination on the Beolink 5000 that duplicates the funtion of the RA/RB key on the 2300.
  • 01-12-2012 7:32 AM In reply to
    • Guy1680
    • Viborg, Denmark
    • Posts 104
    • Gold Member
    I understand but thought that the GOTO TURN may toggle between bands and RA/RB.
    My son has a BC2300 operated with a Beo4 so I'll ask him tonight if he knows of a way of changing it.
    Guy
