1st March February 2012
Latest post 12-11-2011 7:15 PM by Razlaw. 13 replies.
12-11-2011 12:42 PM
Raeuber
- Joined on 12-02-2007
- Posts 986
Hi all,
on my BV 7-40 it is possible to program different positions for the motorstand (video, audio, standby). Normally the positions for audio and standby will be the same.
I have programmed different motorstand position for audio and standby (for test purposes). When I choose an audio source from standby (Radio or CD), the BV 7-40 doesn´t turn to the programmed audio position, it remains in standby position. Only if the BV 7-40 is already in (video) use, the motorstand turns to the programed audio position.
Is this issue correct or a software bug?
Thanks for testing!
Regards
Räuber
Razlaw
- Joined on 04-24-2007
- Illinois
- Posts 1,770
I have never thought about that so I just tried it with my BV7-55. My stand never moves to the Audio position.
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
Raeuber
- Posts 986
Razlaw:
Did you program a different motorstand position for audio in the setup??
Razlaw
- Illinois
- Posts 1,770
Razlaw
- Illinois
- Posts 1,770
I just tried it with my BV 10-40 also. Programmed an audio stand position. Scrolling through the three positions in the steup menu it would turn to each of the three. However, just as with the 7-55, turning an Audio source on does nothing.
Raeuber
- Posts 986
Very crazy! Please check the following with BV 7 and BV 10: Press DTV and wait until picture appears and the motorstand are in video position. Then select P.MUTE or AV DTV. The motorstand should turn to the programmed audio position.
Razlaw
- Illinois
- Posts 1,770
No, does nothing. But it is ot an issue for me. I want the TV in standby position when listening to Audio and ut does that fine. Does not matter to me if a dedicated audio position does not work.
Raeuber
- Posts 986
Hi Razlaw,
ok, but thank you very much for your support. Probably your BV´s need a software update to make it work.
I want to ensure that it works properly with my new BV 7-40 3D.
So probably someone else can answer the question in my first post...
/Räuber
Razlaw
- Illinois
- Posts 1,770
Yes, hope so. However, my BV 10-40 was updated last week with the most recent software.
moxxey
- Joined on 04-14-2007
- South West, UK
- Posts 2,360
Raeuber:
Hi Razlaw,
My BV7-40 has the lastest software and the stand never moves in audio-only mode. I rarely listen to the TV in audio-only mode, so it's not a problem for me. But it's definitely a mode that never works.
Maybe no-one reported it to B&O? :)
Russ
- Joined on 05-07-2007
- Washington, DC USA
- Posts 641
Hello all, silly but please try and report. Go back through the menu set up and store all the settings, then pull main power for 45 seconds, plug back in and try.
We kid because we love.
Bang & Olufsen Tysons Galleria
McLean, VA USA
Raeuber
- Posts 986
Hi moxxey,
on my new BV 7-40 3D the stand moves into a programmed audio position. Only if the TV is off and I press RADIO or CD it doesn´t move. But probably this is intended from B&O.
I assume the latest software is on the new BV 7-40 3D and maybe it´s also available for your BV 7.
/Räuber
Razlaw
- Illinois
- Posts 1,770
Russ:Hello all, silly but please try and report. Go back through the menu set up and store all the settings, then pull main power for 45 seconds, plug back in and try.
Tried what you suggested with my 7-55. It did not work.
Page 1 of 1 (14 items)
