Latest post 12-11-2011 7:15 PM by Razlaw. 13 replies.
Page 1 of 1 (14 items)
  • 12-11-2011 12:42 PM
    Motorstand
    Hi all,
    on my BV 7-40 it is possible to program different positions for the motorstand (video, audio, standby). Normally the positions for audio and standby will be the same.
    I have programmed  different motorstand position for audio and standby (for test purposes). When I choose an audio source from standby (Radio or CD), the BV 7-40 doesn´t turn to the programmed audio position, it remains in standby position. Only if the BV 7-40 is already in (video) use, the motorstand turns to the programed audio position.
    Is this issue correct or a software bug?
    Thanks for testing!
    Regards
    Räuber
  • 12-11-2011 1:45 PM In reply to
    Re: Motorstand
    I have never thought about that so I just tried it with my BV7-55. My stand never moves to the Audio position.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 12-11-2011 1:51 PM In reply to
    Re: Motorstand
    Razlaw:
    Did you program a different motorstand position for audio in the setup??
  • 12-11-2011 2:33 PM In reply to
    Re: Motorstand
    yes
  • 12-11-2011 2:54 PM In reply to
    Re: Motorstand
    So if you have connected an audio source via masterlink to your BV 7-55 and you select Radio or CD, the motorstand should turn to the programmed audio position. My BV 7-40 does so, but only if the TV is switched on before to video.
  • 12-11-2011 3:41 PM In reply to
    Re: Motorstand
    I just tried it with my BV 10-40 also. Programmed an audio stand position. Scrolling through the three positions in the steup menu it would turn to each of the three. However, just as with the 7-55, turning an Audio source on does nothing.
  • 12-11-2011 3:54 PM In reply to
    Re: Motorstand
    Very crazy!
    Please check the following with BV 7 and BV 10:
    Press DTV and wait until picture appears and the motorstand are in video position. Then select P.MUTE or AV DTV. The motorstand should turn to the programmed audio position.
  • 12-11-2011 4:50 PM In reply to
    Re: Motorstand
    No, does nothing. But it is ot an issue for me. I want the TV in standby position when listening to Audio and ut does that fine. Does not matter to me if a dedicated audio position does not work.
  • 12-11-2011 4:55 PM In reply to
    Re: Motorstand
    Hi Razlaw,
    ok, but thank you very much for your support. Probably your BV´s need a software update to make it work.
    I want to ensure that it works properly with my new BV 7-40 3D.
    So probably someone else can answer the question in my first post...
    /Räuber
  • 12-11-2011 5:06 PM In reply to
    Re: Motorstand
    Yes, hope so. However, my BV 10-40 was updated last week with the most recent software.
  • 12-11-2011 5:47 PM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    Re: Motorstand
    Raeuber:
    Hi Razlaw,
    My BV7-40 has the lastest software and the stand never moves in audio-only mode. I rarely listen to the TV in audio-only mode, so it's not a problem for me. But it's definitely a mode that never works.
    Maybe no-one reported it to B&O? :)
  • 12-11-2011 6:59 PM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Re: Motorstand
    Hello all, silly but please try and report. Go back through the menu set up and store all the settings, then pull main power for 45 seconds, plug back in and try.
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 12-11-2011 7:03 PM In reply to
    Re: Motorstand
    Hi moxxey,
    on my new BV 7-40 3D the stand moves into a programmed audio position. Only if the TV is off and I press RADIO or CD it doesn´t move. But probably this is intended from B&O.
    I assume the latest software is on the new BV 7-40 3D and maybe it´s also available for your BV 7.
    /Räuber
  • 12-11-2011 7:15 PM In reply to
    Re: Motorstand
    Russ:
    Tried what you suggested with my 7-55. It did not work.
