Guys I have a problem with my stand, which very stupidly was caused by me! I have just recently brought an MX7000 with a motorised stand, it worked great and I was very happy with the picture and the sound was good to! But I had to move the telly, but I forgot unplug the stand, so I think you can guess what happened! The plug stayed in the Tv and the wire was ripped from the plug. Now I know this is repairable its just a simple case of solering back on the wires, but my dillema is that they are coloured and I don't know which wire goes on which pin in the plug. There is four pins that I need to correctly solder, otherwise it just will not work properly. So guys my question is what wire goes to which pin? Thanks in advance for any advice guys.
Nidul
5 Avant 28" VCR, 2 Silver, 2 Black, 1 Red/Burgandy ;-)
2 Avant 32" VCR, 1 silver, 1 Red/Burgandy
BeoVision MX1500 Black
Beovision MX4000 in Blue with Matching VCR
Beovision MX7000 in Grey with Matching VCR and Active Speakers
1 BeoCord VX7000 VHS VCR
Beocom 1401 with 2 AV Control base
BeoSystem 7000; BeoMaster 7000, BeoGram CD7000, BeoCord 7000 Cassette Deck.
1 Attyca Stand
BeoLink 1000, BeoLink 5000, 1 MCP 5500, 6 Beo4
2 Penta II, 2 RL 45.2
I-Pod Connection!
Trying to MasterLink It all!
