Latest post 12-13-2011 1:53 PM by stotty1111. 4 replies.
Page 1 of 1 (5 items)
  • 12-11-2011 6:31 AM
    • Nidul
    • Not Ranked
    • Joined on 10-22-2011
    • Hitchin, Herts
    • Posts 79
    MX7000 Stand Issue
    Guys I have a problem with my stand, which very stupidly was caused by me! I have just recently brought an MX7000 with a motorised stand, it worked great and I was very happy with the picture and the sound was good to! But I had to move the telly, but I forgot unplug the stand, so I think you can guess what happened! The plug stayed in the Tv and the wire was ripped from the plug. Now I know this is repairable its just a simple case of solering back on the wires, but my dillema is that they are coloured and I don't know which wire goes on which pin in the plug. There is four pins that I need to correctly solder, otherwise it just will not work properly. So guys my question is what wire goes to which pin? Thanks in advance for any advice guys.
    Nidul
    5 Avant 28" VCR, 2 Silver, 2 Black, 1 Red/Burgandy ;-)
    2 Avant 32" VCR, 1 silver, 1 Red/Burgandy
    BeoVision MX1500 Black
    Beovision MX4000 in Blue with Matching VCR
    Beovision MX7000 in Grey with Matching VCR and Active Speakers
    1 BeoCord VX7000 VHS VCR
    Beocom 1401 with 2 AV Control base
    BeoSystem 7000; BeoMaster 7000, BeoGram CD7000, BeoCord 7000 Cassette Deck.
    1 Attyca Stand
    BeoLink 1000, BeoLink 5000, 1 MCP 5500, 6 Beo4
    2 Penta II, 2 RL 45.2
    I-Pod Connection!
    Trying to MasterLink It all!
  • 12-11-2011 9:28 AM In reply to
    Re: MX7000 Stand Issue
    Take a look here on the BeoTech site. Hope that is what you need.
    Stoobie
  • 12-11-2011 10:18 AM In reply to
    • Nidul
    • Not Ranked
    • Hitchin, Herts
    • Posts 79
    Hi Stoobie
    That diagram did help a little, but what I really need to know is what colour relates to each pin. From that diagram I can see that the pins are numbered and what each wire does but not where they go. So if anybody else can help it would be greatly apprieceiated.
    Nidul
    1 Attyca Stand
    I-Pod Connection!
  • 12-12-2011 5:01 PM In reply to
    • Nidul
    • Not Ranked
    • Hitchin, Herts
    • Posts 79
    Anybody out there who can help?
    1 Attyca Stand
    I-Pod Connection!
  • 12-13-2011 1:53 PM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    solder side of plug up, pin arc to top yellow, brown, white, blank ie left to right
    Tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
